Rusty HEI distributor innards?
Old Mar 17, 2017 | 07:30 PM
pmr2000's Avatar
pmr2000
Default Rusty HEI distributor innards?
I changed cap rotor and coil on my stock 75 L48 coupe. The springs and innards have some surface rust, i used a toothbrush to gently clean up a little.....should i spray or clean more aggressively? Runs good as is did not want to mess anything up!
Old Mar 17, 2017 | 07:35 PM
drwet's Avatar
drwet
I've seen worse looking distributors that work just fine. If the advance mechanism moves freely I wouldn't worry about it. I certainly wouldn't use any lubricant in there.
Old Mar 17, 2017 | 07:48 PM
lars's Avatar
lars
Originally Posted by pmr2000
I changed cap rotor and coil on my stock 75 L48 coupe. The springs and innards have some surface rust, i used a toothbrush to gently clean up a little.....should i spray or clean more aggressively? Runs good as is did not want to mess anything up![/i]
Completely normal looking HEI. As long as the centrifugal advance is not seized up, and everything or working freely and smoothly, there is no issue.
Lars
Old Mar 18, 2017 | 10:04 AM
pmr2000's Avatar
pmr2000
Thanks for the assurance! Almost done going through all the regular maintenance items only have the car 2 months, so far so good!
To Rusty HEI distributor innards?
