Brake Bleeder
Old Mar 19, 2017 | 08:49 AM
HT1663WB's Avatar
HT1663WB
Default Brake Bleeder
I need to purchase a brake bleeder for my 71. I've tried doing it the old fashion way but it's not working out. Any ideas? Good affordable unit. Thank, Bill
Old Mar 19, 2017 | 09:01 AM
tyrant's Avatar
tyrant
I did some research here and decided on the Motive Brake Bleeder. It's a nice unit works great. Just use a c-clamp to hold adapter to master cylinder instead of the chains it comes with.
Old Mar 19, 2017 | 09:17 AM
Big2Bird's Avatar
Big2Bird
Yup. Makes life a lot easier.
Old Mar 19, 2017 | 09:30 AM
HT1663WB's Avatar
HT1663WB
Thank you, can you tell me the model number?
Old Mar 19, 2017 | 02:21 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
I also bought the Motive bleeder and also installed speed bleeders. I did the job with the speed bleeders and the brakes feel fine. I use bleeder for larger jobs.
Just check the motive site for the models and find the one for your application.
Old Mar 19, 2017 | 02:42 PM
kansas123's Avatar
kansas123
Motive Bleeder is the only method I have not used so can't comment on it. However, I am absolutely sold on gravity bleeding, it's the only thing I finally got to work and it's very easy to do. Good luck on your brakes.
Old Mar 19, 2017 | 04:41 PM
FKING1's Avatar
FKING1
Could never get my Motive to work, always leaked.
Bought a unit from Summit that connects to air compressor an no more problems.
Old Mar 19, 2017 | 06:15 PM
C3 4ME's Avatar
C3 4ME
Another vote for a Motive bleeder. I've been using mine a lot lately working though a brake problem, it works great every time. As I recall is was about $70 from Zip probably 8 or 9 years ago. Money well spent! I was highly impressed the first time I used it on how much better the brake pedal felt, as compared to manually bleeding the brakes.
Old Mar 19, 2017 | 07:29 PM
sunflower 1972's Avatar
sunflower 1972
I've had good luck with Mity Vac: https://www.napaonline.com/en/p/BK_7003882
It can also be used to test various vacuum controls and switches.
Old Mar 19, 2017 | 09:30 PM
ace_cobra's Avatar
ace_cobra
You have a distribution block, similar to my 1970. It wont cut pressure off indefinately, it will shuttle pressure from front to back and return to normal state when equal. So what I did was bled the rear, then the front, and the rear. No issues here.
Old Mar 20, 2017 | 01:27 AM
ramair_bryan's Avatar
ramair_bryan
Fellas.........
I too needed an easy, affordable way to do this. I have to bleed every month on the RR wheel caliber.
Used a syringe we used for cattle. It's big, not like your thinking on people.
Slid a 1'' clear hose over the end after I cut off enough that the hose would slide snug.
Go to the master cylinder. Draw out from it to fill the syringe. Slide the 1'' hose onto the caliper bleeder. loosen it 3-4 turns and push fluid back up the brake line filling the reservoir.
Do this 3 more times and your done. ...
Don't forget to put the lid back on the reservoir before you push fluid.
It'll hit the top of the barn.....
Visit a farm supply near you.
Your welcome.
To Brake Bleeder
