listing/leaning to the left
Old Mar 21, 2017 | 10:06 PM
GMAN72's Avatar
GMAN72
Cruising
Default listing/leaning to the left
just finished a near frame off resto trying bring my 72 coupe back to life. new upper and lower control arms from global west. vicking coil overs, composite mono spring on rear. was sitting level side to side on frame machine. then after driving a short while notice car leaning to the left 1/2 to 3/4 inch. any Ideas what the problem may be and how to correct it???
Old Mar 21, 2017 | 11:00 PM
TOM B1's Avatar
TOM B1
From the parts list you installed There may be a few things that can happen when driving but look good on a rack, first is the front coil overs from Vicking, a very good product and has a adjustable spring rate adjustment ring that may have come loose and slipped down to let the car lean, I think these can move a whole inch. Next is the rear mono spring that must be re-adjusted after driving the first time, I noticed that the left spring adjustment bolt needs just a few more turns than the right on most early vettes. also retighten the center spring saddle bolts. also check for binding bushing like swaybars ect.
Old Mar 22, 2017 | 10:07 AM
7T1vette's Avatar
7T1vette
Was the car level on the ground before you tightened up the front suspension fasteners?
Old Mar 23, 2017 | 03:25 PM
GMAN72's Avatar
GMAN72
Cruising
Default leaning left
Have checked coil overs, adjusters were tight and in position as set. checked for any binding issues prior to and after driving. Will check the rear mono spring saddle bolts tomorrow, and add a couple turns on the left side spring adjustment bolt. thanks for the help
Old Mar 23, 2017 | 03:34 PM
GMAN72's Avatar
GMAN72
Cruising
Front coil overs were put on, car set down on wheels and ride height adjusted with weight off tires each time, shocks were with in 1 turn of each other, then this issue was noticed after driving a short time. Coils are seated in upper spring holder as should be.
Old Mar 23, 2017 | 04:02 PM
7t9l82's Avatar
7t9l82
Sway bar adjustment?
Old Mar 23, 2017 | 05:36 PM
GMAN72's Avatar
GMAN72
Cruising
well now hadn't looked at that. Have only front sway bar. Do you measure that by sway bar tip to frame?
Old Mar 23, 2017 | 10:29 PM
TOM B1's Avatar
TOM B1
If all looks good and nothing moved then all you need to do is a common readjustment to all 4 corners to get it level. Nothing today is made to exact specs so things like coil springs and mono springs may have different spring pressures from side to side so after a test run it is common practice to make a readjustment.
Old Mar 24, 2017 | 01:41 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Pick up any weight since Thanksgiving dinner...???
Just kidding....
Good luck finding the problem.
Old Apr 7, 2017 | 10:25 PM
GMAN72's Avatar
GMAN72
Cruising
Just kidding....
great reply...thanks for the laugh!!!
Old Apr 9, 2017 | 01:49 PM
bmans vette
Glad to see you have a sense of humor.
Ever find the problem/solution?
To listing/leaning to the left
