wheel spacers/adapters, where to get them
Old Apr 1, 2017 | 06:50 PM
george2066's Avatar
george2066
Default wheel spacers/adapters, where to get them
putting on 18" wheels, going to need spacer/adapters. Who did you buy from?
thanks
Old Apr 1, 2017 | 08:46 PM
gjohnson's Avatar
gjohnson
I ordered mine through Motorsport Tech out of Reno Nevada ,custom-made to your specs
Old Apr 1, 2017 | 08:55 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I got some nice ones from Smiley's racing. Circle track guys use them all the time.
Other than that Summit and Jegs carry cast and billet ones.
JIM
Old Apr 2, 2017 | 12:08 PM
Cool95vette's Avatar
Cool95vette
I have these on my car.
http://www.ebay.com/itm/2-12MM-5X4-7...9V3wpx&vxp=mtr
Old Apr 2, 2017 | 09:35 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I was told that you need hub centric spacers to center the wheel correctly. justs passing it along if no one had mentioned it
Old Apr 3, 2017 | 10:32 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
you are correct highly recommend hub-Centric adapters Only.
you must figure the dimensions you need for your individual wheel and offset.
in general you need about 2 in the front, and 2.5" in the rear.
again all this depends upon the specific wheels you choose, if your buying new,
get the correct fitting wheels so no adapter is required.
here is link to a concentric 2" adapter on ebay.
http://www.ebay.com/itm/151974323188...%3AMEBIDX%3AIT
these are 17" using 2" in front, and 2.25 " in the rear concentric adapters.
Old Apr 4, 2017 | 12:04 PM
Silvertone's Avatar
Silvertone
Originally Posted by Cool95vette
I wouldn't call these hubcentric if they don't help locate the wheel to the hub. Mine have a 1/2" protrusion that fits snugly inside the wheel bore to center the wheel to the hub. 3.07" diameter in the case of my particular wheels. The inner bore to fit the Chevy hub should be 2.78".
I used 3/8" on the front and 1/4" thick on the rears to get the right fit. You'll need to use long reach lug nuts unless you want to install longer wheel lugs. If you want to use longer lugs to add up to an inch, I would recommend Milodon 86050. All these longer lugs will require reaming the bores due to thicker knurl diameter, and the Milodons only add .005" additional knurl diameter. Fronts are easy to fit, rears are more complicated to get in and out.
(Stock studs are 1.75" long with .475" knurl diameter. Milodon 86050 are 2.625" long with .480" knurl.)
For the OP, have you received your new wheels yet? And can you measure the backspacing? I'm assuming you just need 1/2" or less changes to your desired wheel's position. If you're using newer C5 style wheels you'll need a 2" thick adapter and that's a whole different discussion.
Steve
Old Apr 4, 2017 | 12:08 PM
Silvertone's Avatar
Silvertone
By the way, Motorsport Tech is a good place to get them once you know your exact specs.
To wheel spacers/adapters, where to get them
