hei distributor question
Old Apr 7, 2017 | 08:50 PM
rcread's Avatar
rcread
I don't know why this would solve your problem.
Old Apr 16, 2017 | 03:47 PM
CB1974's Avatar
CB1974
Cruising
Hello again, I decided to go with the igniter III, I just have one more question. I pulled out the distributor for ease of installation and so I could check the end play of the gear. The end play is .075. Is that too much? What should it be if I will be running the igniter III? Thanks
Old Apr 16, 2017 | 03:49 PM
Big2Bird's Avatar
Big2Bird
Cast iron dizzys about .020" Aluminum units about .030-.035"
Old Apr 16, 2017 | 04:09 PM
CB1974's Avatar
CB1974
Cruising
Sorry to keep asking questions it another just came up. The instructions say to bypass the resistance with standard copper wire, but I read somewhere that you can just put a relay on the insisting wire. Will this work or would it be better to bypass it?
Old Apr 16, 2017 | 07:51 PM
Big2Bird's Avatar
Big2Bird
I would bypass it, or just use a keyed on hot lead. Yellow wire on wiper motor works fine.
