69 stingray fuel pump how to
Apr 6, 2017 | 06:09 PM
1st Gear
I need to change the fuel pump on a 69 stingray 350 SB, there's no easy way of course but is there a best way or quickest? Pull motor? inner fender/tire? Pay someone to do it?
Apr 6, 2017 | 06:19 PM
Should be fairly simple. You can get it from underneath or leaning over the fender. The pushrod can be tricky if you haven't done one before.
Apr 6, 2017 | 06:36 PM
Hi jtm,
Welcome !
First post!!
Access to the fuel pump from below is quite good.
It has 2 bolts that attach it to the block.
Good Luck.
Regards,
Alan
From the front:
From below:
Apr 6, 2017 | 07:28 PM
From under. BTW it's going to pour gas so clamp the rubber line 1st.
As for the rod crank the engine so the rod is in the furthest. I think having the #1 piston at TDC does the trick but check that.
Mine was simple to install at TDC.
Apr 7, 2017 | 07:54 PM
+1 on the fuel clamp - tank is higher than the pump so it will drain the tank before it stops
Apr 7, 2017 | 08:56 PM
You can hold the pushrod in place by putting a little cold grease on the tip that goes against the cam.
Apr 7, 2017 | 09:07 PM
I seem to recall there's a bolt that's in line with the fuel pump push rod. Remove that bolt, install a longer bolt (don't recall what length) to hold the push rod in place.
Apr 7, 2017 | 09:15 PM
Quote:
Originally Posted by
sunflower 1972
And don't forget to use sealant on the bolt when you put it back in.
Apr 7, 2017 | 09:37 PM
rcread
That's the way I do it. I don't like the bolt method as I'd probably forget to take it out.
