George
Old Apr 6, 2017 | 07:36 PM
383strokedc3's Avatar
383strokedc3
2nd Gear
Default George
Is there anything special or anything I should know to install a set of Gabrial Air shocks on the rear of my 1976 Corvette ?
Old Apr 6, 2017 | 07:54 PM
Dynra Rockets's Avatar
Dynra Rockets
They still make those? Other than knowing your ride quality will suffer, no, there is nothing special to know.
Old Apr 7, 2017 | 11:38 AM
MelWff's Avatar
MelWff
why would you do that? are you happy to constantly change the half shaft u-joints
Old Apr 12, 2017 | 11:33 AM
383strokedc3
2nd Gear
Default Heat issues under the hood
can anybody help me? Going nuts!!
I have a 1976 C-3
i put a 383 Stoker with 500 HP in the car.
now that it is getting warmer 75 degrees and above, I am having vapor lock isdue with my fuel lines which are stell braid and just about a stock run up from the fuel mechanical fuel pump to with a glass gas inline filter to a Quick fuel 750 carb and putt gas line insulator condoms on the lines aft the fuel pump.
Run great on cooler !
can anybody give me any Ideas on what to do to correct these issues ??
Old Apr 12, 2017 | 12:15 PM
gveld's Avatar
gveld
What type of gas are you running ? I was having similar problems last year with new motor install . I found info that gas with Ethanol in it will boil at lower temps than non Ethanol fuels . I switched to non Ethanol fuel and problems went away .
Old Apr 12, 2017 | 12:26 PM
MelWff's Avatar
MelWff
Default From shock to vapor lock
I have a 1976 C-3
So a mid course correction from air shocks to vapor lock.
What are the symptoms you are experiencing?
Are the float levels correctly set?
Are you running a return line?
Do you have any kind of spacer between the intake manifold and the carburetor?
Old Apr 12, 2017 | 06:24 PM
vettebuyer6369's Avatar
vettebuyer6369
I have a 1976 C-3
Would you like your title changed to something that would make people know what the topic of the thread is? maybe you will get more input?
Old Apr 13, 2017 | 07:43 AM
gdh's Avatar
gdh
I would get rid of that glass inline filter and replace it with a good metal one. Remember if that glass breaks you have gas pouring unto a hot engine.
I would opt for a better shock, many here use Bilsteins but others will certainly chime in with good recommendations based on experience in their C3's.
MelWff's questions need to be addressed, what happens when you open your gas cap after a run? Have you tested with a vacuum gauge?
To George
