Cam Bolts?
Old Sep 26, 2002 | 03:26 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Cam Bolts?
I'm going to use a locking plate on the 3 cam bolts that go thru the timing gear. Do I need to use lock washers or start washers also?
Old Sep 26, 2002 | 03:33 PM
Fevre's Avatar
Fevre
Default Re: Cam Bolts? (Paul 75 L82)
I would think not since they would get in the way of the locking plate tabs getting on the bolt edges. I did not use any when used a locking plate during my roller cam intall.
Old Sep 26, 2002 | 03:39 PM
Paul L's Avatar
Paul L
No. This is all you need. The torque is 20 ft-lbs.
Old Sep 26, 2002 | 03:40 PM
The Dude's Avatar
The Dude
Negative.
A little medium Loctite on the threads and bending the tabs is all the insurance you need.
Old Sep 26, 2002 | 04:12 PM
Paul 75 L82
Default Re: Cam Bolts? (The Dude)
Thanks Guys, I'm building a new 383 for my 73 Z-28 (Corvette motor is still good-to-go!) Bought the short block from Wheller Motorsports in Jax, Fl. for about $1600. Received block yesterday and it looks real good.
Old Sep 26, 2002 | 09:21 PM
ZD75blue's Avatar
ZD75blue
anyone used studs, and some lock washers/bolts?
Just an idea
ZD
To Cam Bolts?
