Tool Part Number
I don't want to take a chance with a used tool again, and snap-on doesn't call it the socket a T500 anymore. The snap-on site has a "Bit, TORX (GM-style), T47 and it is part number FTX500E2, and they have a socket driver P/N GFTX500E.
Will either of these work, and is one preferrable to the other? I'm a little confused because I thought the seatbelt bolts were T50 with thicker splines. This looks like a T47, which seems like it would be too small.
Finally, any tips on getting these bolts out would be appreciated. Has anyone used MAP gas to heat them up from the rocker channel side, or is there a risk of heating the buckle and scorching the belt?
MajD
Most seat belt bolts have a factory lock tight thread locker so they dont come loose.
heat is the key to loosen these bolts but all carpet and burnables must be pulled away, have a water bottle handy.
Another way to get these out is with a impact driver
