69 C3 Corvette not getting gas
Old Apr 16, 2017 | 01:53 PM
GuyV69's Avatar
GuyV69
2nd Gear
Default 69 C3 Corvette not getting gas
Had front jacked up to chahge oil with low fuel. Added gas but still not getting fuel to caborator,
Old Apr 16, 2017 | 07:17 PM
TimAT's Avatar
TimAT
Either the fuel pump has gone to fuel pump heaven (or where ever they go), or there's a leak on the suction side of the pump. But it may be a easy as the pickup tube in the tank got uncovered and all the gas in the fuel line went back to the tank- leaving you with an empty line, empty pump, and a really long cranking time to fill it all back up.
Old Apr 17, 2017 | 04:23 AM
SB64's Avatar
SB64
Default gas
Here's another thought. The fuel hose on the 69 can have a crimp in the way it routes from the pump to the line on the top of the frame. Check that area.
RVZIO
Old Apr 18, 2017 | 02:41 PM
MelWff's Avatar
MelWff
did you look into the tank with a flashlight and can you actually see gasoline?
do you have a vented gas cap?
add some gasoline to the tank.
Old Apr 19, 2017 | 08:23 AM
3X2's Avatar
3X2
Remove the hose from the fuel pump inlet and see if fuel flows out. If it's like 69, it will flow pretty good. If you got fuel there, disable the ignition and loosen the fuel line inlet at the carb, crank engine and see if fuel is there. Plugged fuel filter??? Stuck needle & seat??? Fuel cap not venting??? seems strange this would happen after jacking upi the front of the car.
To 69 C3 Corvette not getting gas
