1969 Accelerator Rod Mod?
Old Apr 17, 2017 | 04:18 PM
CrossedUp's Avatar
CrossedUp
Default 1969 Accelerator Rod Mod?
I'm not sure if this was a solution to a known issue or a PO that drove with an extremely heavy foot
-Doug
Old Apr 17, 2017 | 04:40 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
very common C3 problem, gas pedal bar gets bent from being stomped.
that was someone solution, maybe not the best way.
Old Apr 18, 2017 | 08:54 AM
CrossedUp's Avatar
CrossedUp
Thanks 69Vett,
You know of a better solution?
Old Apr 18, 2017 | 10:22 AM
69Vett's Avatar
69Vett
if you simple install correctly, so that the pedal reaches floor and end of cable(wide open)
at the same time. you should no longer have the issue of bending the pedal rod, you won't be pushing the pedal rod, beyond the cable maximum limit.
To 1969 Accelerator Rod Mod?
