Steeroids ujoint stuck on?
Old Apr 21, 2017 | 10:00 PM
glarior's Avatar
glarior
Default Steeroids ujoint stuck on?
Any suggestions to remove a stuck ujoint on the steeroids steering shaft? Ive sprayed it down with PB Blaster and no luck. Looks rusted. Ideas?
Old Apr 22, 2017 | 05:59 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Which joint upper or lower? Aluminum or polished stainless? Did you unbolt and lower the rack? If steel you can use a brass drift. Sometimes it takes a few days for penetrating fluids to work, apply daily and work it. T
Old Apr 24, 2017 | 02:38 PM
glarior's Avatar
glarior
Upper joint and aluminum. I did not unbolt the lower rack. This weekend I am trying ATF mixed with acetone and see if that will free it up any. When it was new it would slip on semi easy.
How does unbolting the rack help? Does it give it a easier angle?
Old Apr 25, 2017 | 08:17 AM
terrys6t8roadster
If the rack isn't separated from lower u-joint, where does the u-joint shaft assembly have a place to travel to, or are you expecting the upper u-joint to slide on to the spline of the lower shaft. Give it some room to move, it's only 2 bolts[saddle on the drivers side]. T
Old Apr 25, 2017 | 10:38 AM
glarior's Avatar
glarior
I did not think of that at all. I will try that this weekend. Thanks!
Old Apr 26, 2017 | 07:48 AM
terrys6t8roadster
Let me know how it works out, keep soaking every day. T
To Steeroids ujoint stuck on?
