We talk about how long solid rollers will run on the street....
Well this is a picture of a 10 year old set of Morel 4845's. These are pressure fed needle bearing lifters that have 3000 street miles and hundreds of passes. This is a 3500/3600# car that runs 9.60's on pump gas. this is 496 build that has been shown no mercy. This was the first time the valve covers had been off this build in the 10 years it has been together....
Well Chris, my Morel bushing lifters I got from you should last awhile then. Great post! Makes me glad I didn't compromise and go Hydro roller. Time will tell!
Good Oil, proper valve spring pressure, and keeping a good lash should help keep the cam and lifters happy. Large rollers are typically not designed for everyday driving.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's only an average of 300 miles a year. Are these lifters primarily for trailer or garage queens?
I'm going to find out. I went with the .904 lifters- bigger roller, more needles= spread the load out more. Plus the roller turns a little slower. With the pressure fed bearings, and good oil, they should last. And I AM planning on driving it as much as I can. I'll pull the intake and take a look at them in about 18 months- find out if I made a good or bad choice.
I have to admit I too was thinking that 3,000 miles isn't much... I've covered nearly 5,000 in my Vette since the start of the year, and I can't really fathom only driving it through a couple of tanks of fuel a year.
I ve never kept good records on my two crane pro solid rollers but 20 to 30K miles If I had it to do over I would have had the blocks machined to bbc. 903 dia and bought Chris's solid bushing. 810 roller wheels
I've been running .842 Crower HIPPO lifters for several years now on a 268/274@.050 solid roller. It's not a high mileage setup, but it sees plenty of stoplight idle time. I plan to inspect the lifters at the same interval I would check the valvesprings, unless the lash moves more than it should. I do however maintain a relatively high idle speed just in case.
I put about 4000 miles on my Comp Cams solid rollers. The lobes on my cam are pretty aggressive with not a lot of lead up ramp. This makes me able to run a tight lash. I run .010" and .012" hot. The tighter I run the lash, the better the engine likes it, mostly because the cam isn't too big for the combo.
I check the lash quite often and if I ever hear any tick whatsoever, it will get shut down and hauled home.
Tough to beat the "bushed" rollers, good friend/customer has a set of Isky's in his '56 Chev for over 6 years now, no real issues.
This is a N.Y. registered 100% street-legal ride, a constant "Drag-Week" contestant and winner. Every one of these events the ride attends he racks up about 2500 miles all tolled traveling from track to track and racing.
Does much other racing also at nearby tracks including Maple Grove and down in the Carolina's!
Up around 1800 HP, close to 3800# (still), runs 7.50's @ 190.
If you want a good lifter by all means go "bushed", you'll never regret it.
Thanks, Gary in N.Y.
P.S. We find the same performance/service from Comp's new one's also. With the ride above we have absolutely no more "broken" parts, this includes lifters, springs, and now rockers. Just eliminated the needle brgs in the T&D's, went over to bushings there also.
Real hot rods have solids rest can sit at the little kids table.
I do a lot of road course track days with my '69. I have yet to see a solid lifter Corvette out on the track with me (I'm running hydraulic flat tappets). Any other Corvette I see is running hydraulic rollers.
The "real hot rods" must be hanging out at the local drive-in, 'cuz I ain't seeing any at the track.
That sounds pretty good, thanks for the info. When they went bad, were you able to catch them in time and just replace the lifters, or did the engine require a complete rebuild?
They are still running I use VR 1 motor oil , priority main blocks, high volume oil pumps, about 30 psi hot idle
The motors have both been refreshed with the same lifters going back in. The springs, rings, and valve guides go
69427 with no other changes other than a roller cam you could gain significant amounts of power across all rpm. Then quit worrying about using your lighter weight brake rotors and minor additional gains flat bottoming your car to a higher level. Actually your car would be so much faster that you would finally understand that stock brakes are incapable of running more than just a few laps before failure
