I see where there is a mysterious switch is mounted on the Wiper Door Actuator housing in my 72. Might this be the hood ajar switch and if so where under dash does the "white wire" connect? (Brown wire protuding out of harness maybe?
Thanks in advance
Dougtov
Wow, what a nice looking compartment! Yes, that's the switch. I believe you are all correct in that the switch is the alarm trigger. I found the female end that is in the rear wire harness and plugs in under dash. The white wire goes to the relay in jack compartment behind pass seat. Thanks for jumping in on this. BTW, Alan, got anymore photos of your C3?
I have to know the level of restoration to achieve!!
Dougtov
Hi D,
WELL!!!!!!!!!!!!!! Thanks but….
Here's the funny thing….. that's not my car!!!
That's a car that was restored by member Rowdy Rat. Stan Falenski.
I'll post another of IT and one of mine!
Regards,
Alan
