Alternator mistery denomination
The previous owner installed a new alternator several years ago, but I have no way to identify what the Amp. capacity is.
There is one blurred bar code, but I'm not able to find out which one I'm running with.
Any help is more than welcome
With engine idling at 900rpm shows around 7A....with lights on around 15A.
Is it not this a too low comsumption?
My car is a A/A model (compressor out), but since the alternator has been replaced in the past I don't know what is running now with.
My intention is to install Ford Focus fans so wondering if with the 61A alternator would be enough.
If the alternator at one time was 61 A- that's the maximum output- usually around 2000-2500 RPM. Looks to be an aftermarket- so there's no idea if it puts out what it's suppose to.
First problem-Most of the time the fans turn on at idle- sitting in traffic AND the alternator is not going to be putting out anywhere near the maximum output.
Second problem- when the fans start up- they pull a tremendous amount of current- often double the rated consumption.
Third problem- your charging wire/harness was not designed to handle these amounts of current.
I'd do it right...replace the alternator and charging wire...
Richard
Richard
Anyhow, I plan to replace the Alt just in case I finally decide to put the A/A compressor back.
Any recomendation about the charging wiring size?
https://www.corvetteforum.com/forums...lternator.html
I'd go 8ga minimum on wire size. The bigger the better.
Any recommendation about the charging wiring size?
The 74 didn't have an electric fan for the condenser- and the blower fan is the same for non-AC equipped cars. Guessing GM thought you'd be running the AC in traffic at idle with the blower fan going- and a little bit of extra charge would help
I'd go with at least a 6 gauge wire from the Alt to the starter lug.
I'd wire the fan(s) to the starter lug as well.
Another problem- replacing the charging wire will make your ammeter read incorrectly. A voltmeter replacement will solve that problem.
Richard
The charging wire to the solenoid has to be 6 gauge. I would run 6 gauge to a large terminal block where you can connect the fans and then continue it down to the solenoid.
Hook the voltage sensing wire for the alternator to this new terminal block.
Then, re-route the existing wire(s) which power the firewall plugs to this terminal block too.
Richard
So based on your comments I don't have to change wiring from the battery to the Alternator, right?
What about if the fans are running with the engine off?, the battery would be feeding the fan or fans with a smaller cable.
What I'm not able to find is where the hell ends up the positive cable from the battery, and that's a big one when leaving the battery.
So, upgrading up to 6ga from alternator to the terminal block and then to the starter would be the first step. Wiring both fans to the same terminal block with 10ga cable would be the 2nd step.
But I guess I cannot install a second 6 ga cable from the starter to the battery since I would be feeding with 12V the starter from 2 different sides (battery and Alternator)
BTW, can be these CS144 or AD244 alternators be purchased with V pulleys on it cheaper than $200 ?
I think this way is how my car is running now, I mean there is a terminal block in the middle of the Alternator - Starter line, and some other cables like MSD ignition ans firewall from there, but they are not definetly 6ga, I'd say 10 ga.
I just wrapped it a little bit with red tape to be clear, even though with that size is clear.
So now makes sense your recommendation.
Question is, should I replace the existing cable from Alt to the starter (PITA) or by adding a new 6ga one on the existing 10ga will be enough? In any case what are the fuses recommended for such installation?
Put in a BIG alternator and install a BIG power wire from it.
Yes- replace the cable and the alternator...
Here's a chart of why 6GU is a good idea- I used 8ft and 61A...
Link- https://www.wirebarn.com/Wire-Calculator-_ep_41.html
Unless you've replaced your engine harness- you have 40+year old wiring- it was too small when the car was new- as GM cut corners-
Read over this and you can decide whether or not it's a good idea to run the stock wiring...
http://www.madelectrical.com/electri...evymain1.shtml
The red wire that is taped into that harness is the one you are replacing. I would use a 10 gauge fusible link on the end of the new 6 gauge wire.
What I meant by a possible solution is to keep the current installation and adding a paralel one with 6 ga wire and proper fuse, this way the voltage would dropped even less...maybe I'm wrong.
Otherwise unplugging the old one and adding a new one woth 6 ga wire may be another solution to keep the original harness just in case.
Now trying to find a good CS144 140A with V pulley
