74 transmission fluid change
Old Apr 26, 2017 | 01:39 PM
mikedeleon66's Avatar
mikedeleon66
4th Gear
Default 74 transmission fluid change
Sorry if this has been addressed but i searched and did not find anything.
Anywho, I picked up a 74 350ci 4-speed manual recently and have looked around for details regarding changing the transmission fluid with only some luck.
Can someone help out a newbie here? I haven't jacked up the car yet but I assume there is a drain plug and a fill plug. Is it as simple as that?
And what kind of fluid do you recommend? The original manual says SAE 80 but what is recommended in 2017?
I appreciate any help.
MikeD.
Old Apr 26, 2017 | 01:46 PM
MelWff's Avatar
MelWff
some Muncies have a drain plug, yours might since it's a 74. If not the fluid has to be pumped out like on my 1969. I use valvoline gear oil 75W90 not synthetic.
Old Apr 26, 2017 | 01:50 PM
mikedeleon66
4th Gear
thanks for the quick reply. I hope it has a plug.
Old Apr 26, 2017 | 08:36 PM
flyeri's Avatar
flyeri
If it has drain and fill plug, open the fill plug first. You don't want to drain it and then find you can't readily get the fill plug open. It happens.
Old Apr 26, 2017 | 11:37 PM
corvetero's Avatar
corvetero
Mine is 74 and has drain plug on the M21.
BTW, I put this oil last year, and so far so good.
Old Apr 27, 2017 | 08:46 AM
mikedeleon66
4th Gear
appreciate it!
Old Apr 27, 2017 | 01:17 PM
MelWff's Avatar
MelWff
sears carries 8 point sockets that are perfect for removing the plugs
Old Apr 27, 2017 | 01:20 PM
corvetero's Avatar
corvetero
Plugs are all square, aren't they?
Old Apr 27, 2017 | 02:09 PM
pmr2000's Avatar
pmr2000
They are all square on my '75, I could not get the drain plug off so had to pump it out painfully through the fill. Is on right side on mine.
Also did the rear also that had no drain, removed right rear wheel for access. I used Mobil 1 with LSD additive, so far no complaints.
Old Apr 27, 2017 | 02:48 PM
MelWff's Avatar
MelWff
Default socket
You are correct which is why a 8 point socket gets excellant grap on the plug.
Old Apr 27, 2017 | 10:08 PM
C3 4ME's Avatar
C3 4ME
Yes, 8 point sockets are the secret trick on the square plugs. That's what I had to use to get the fill plug off of my trans, as a open ended wrench did give enough leverage. I used the 8 pt socket with a long handle ratchet.
Old Apr 28, 2017 | 09:33 AM
gkull's Avatar
gkull
I just rebuild a friends m22. You want the best to make it last. Brad Penn 80w 90 gear oil for brass syncromeshs
Old May 1, 2017 | 11:20 AM
mikedeleon66
4th Gear
So why does the original owners manual state that GL-5 should be used? Does this transmission have brass parts that GL-5 is supposedly harmful?
thanks
Old May 1, 2017 | 12:18 PM
jb78L-82's Avatar
jb78L-82
gmheritagecenter.com
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
lists the gear oil for the manual tranny as GL-5 (ML-L-2105B) which is GL5. Use the GL-5 gear oil, preferably a synthetic, which are far superior to conventional gear oil...synthetics did not exit in 1974 and you will not see a recommendation from GM for them since they were not around then. As long as it is GL5 you are good.
BTW-I bought into the GL4 recommendation for the manual tranny's without checking gmheritagecenter.com and currently have Redline GL4 in the tranny and just checked the reference for 1978 Corvettes when researching your question and guess what? My 78 also calls for GL5 which I used for years until the switch 2 years ago to the Redline synthetic GL4. Back to GL5 synthetic Mobil 1 75W-90 when I get a chance.
Old May 25, 2017 | 10:59 AM
4speeds's Avatar
4speeds
Here an interesting video on some oils
Old May 25, 2017 | 05:09 PM
LS4 PILOT's Avatar
LS4 PILOT
i really see reason to drain it , generally for street driving it lasts a very very long time ...but can slowly leak out drop by drop over decades. just stick your finger in the fill hole see it it is low ..add till your finger touches the oil ...add a high quality tranny oil for old school transmission . i used Classic trans type Redline brand in my Z28 350, because i had it rebuilt . The auto parts store had to order it. most of that cheap stuff is for modern cars with plastic parts . If you add any in .....use the correct lube .
don't make up work ...
To 74 transmission fluid change
