Performance
Old Apr 28, 2017 | 03:46 PM
PM427's Avatar
PM427
Default Performance
I have a 69 427 390 hp stingray with a rochester carb. Points and condenser replaced. New Cap, rotor, wires, plugs as well as a carb adjustment.
Cars runs great normal driving. As soon as u put your foot in it it boggs down. Didnt have this issue before tunup.
Rechecked wires and such and all all looks good including vacuum hoses.
Any suggestions advice?
Old Apr 28, 2017 | 04:12 PM
AirBusPilot's Avatar
AirBusPilot
Bogs, then recovers?
Pull the air cleaner off and move the throttle full range and see if the accelerator pumps are giving a good stream of fuel (engine off).
Old Apr 28, 2017 | 04:39 PM
MelWff's Avatar
MelWff
you replaced the points and condenser but make no mention of setting the dwell and checking the timing with the vacuum line to the distributor disconnected, did you perform those two tasks?
on the passenger side of the carburetor, any vacuum hoses accidentally disconnected?
with the engine off can you feel a slight resistance when you press down on the secondary air valve?
Old Apr 28, 2017 | 04:57 PM
dmaxx3500's Avatar
dmaxx3500
rebuild the carb,,the accelerator pump is probably bad
Old Apr 28, 2017 | 05:12 PM
PM427's Avatar
PM427
Thanks guys. Yes the dwell and timing was set. My bad for not adding that. I will check the fuel and i believe as you that a carb rebuild may be in my future. Appreciate the advice and replies guys.
You helped me out a lot.
Old Apr 28, 2017 | 05:14 PM
PM427's Avatar
PM427
Yes thats exactly what it does.
Old Apr 28, 2017 | 08:03 PM
Big2Bird's Avatar
Big2Bird
The NAPA kits are good, and have the alcohol resistence accel. Pump.
Old Apr 28, 2017 | 09:01 PM
drwet's Avatar
drwet
I'm having a hard time believing this is a carb problem if the problem didn't exist prior to the tune up. That's a helluva coincidence. I'd be rechecking what you did when you did the tune up.
Old Apr 28, 2017 | 10:14 PM
Big2Bird's Avatar
Big2Bird
Good ponit.
Old Apr 29, 2017 | 07:04 AM
7T1vette's Avatar
7T1vette
Did you check where the timing was set BEFORE you changed it to factory spec? Factory spec timing is WAY retarded for an engine set up for performance. Move timing up to 12 deg. BTDC with the vacuum advance line pulled and blocked. THEN see how it runs.
Old Apr 30, 2017 | 10:50 AM
PM427's Avatar
PM427
I moved the timing up a bit and the prob is almost gone. Thank you for the advice.
Old Apr 30, 2017 | 02:53 PM
7T1vette's Avatar
7T1vette
GM set VERY mild specifications for stock timing requirements. They did so in order to minimize warranty costs; if the cars didn't get "stressed" to their potential, there would be less engine damage incurred. Worked pretty well....for them.
Most stock engines will perform MUCH better with base timing set to 10 -15 degrees BTDC on the compression stroke. There are detailed procedures to maximize potential by dialing-in the distributor. But, just advancing timing a few degrees will make a substantial improvement in engine performance.
Old May 1, 2017 | 07:56 AM
gguillot's Avatar
gguillot
Did you relocate your vacuum advance line for the distributor when you did your tune-up? Make sure it is pulling from manifold vacuum and not a ported vacuum port. Also, re-torque your carb mounting bolts (I think it is 10-12 ft lbs. on the quadrajet, IIRC.)
I solved my off idle stumbling problem on my '73 recently just by doing these two things.
To Performance
