Right vs Wrong Alternator Adjustment Brace
Old May 1, 2017 | 12:27 AM
AboveTheLogic's Avatar
AboveTheLogic
Default Right vs Wrong Alternator Adjustment Brace
Some previous owner installed a universal alternator adjustment brace on my C3 before i bought it. It was always tricky adjust it correctly where the alternator cooling fins don't contact the brace.
Finally got annoyed enough to drop the $22 plus shipping for the factory unit.
Here are some photos of the differences. Super easy to adjust now.
Old May 1, 2017 | 12:38 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Actually the alternator bracket goes to the other side of the alternator "tab".
Old May 1, 2017 | 12:40 AM
AboveTheLogic
Ha! I'll be damned. On the front side is the only way it worked with the old bracket, see what I mean from the photo?
Old May 1, 2017 | 01:42 AM
KapsSA's Avatar
KapsSA
Yeah, see the problem.
I believe that old bracket would work correctly on an 80-82 as those years the bottom mount is higher up at the main alternator bracket and not at the water pump.
Try holding it up to that bolt kinda behind it and see how it lines up.
I have one of those brackets I've been trying to give away for years...
Old May 1, 2017 | 06:24 AM
Alan 71's Avatar
Alan 71
Hi ATL,
Since the bolt appears to be right at the limit of the adjustment range I'm wondering about the length of the belt you're using too?
This a a 71 sb configuration/installation.
Regards,
Alan
Old May 1, 2017 | 10:37 AM
AboveTheLogic
Interesting. Now that you bring up the belt length, I remember now that I used to have to remove the alternator to remove the drivers side valve cover. I don't quite remember but I might have bought a longer belt in an effort to avoid having to do that. Never helped.
When it comes time to change the belt, I'll get the stock length and see if it makes a difference. I'll see about moving the mount to the rear of the adjustment tab as well. I actually have several washers between the adjustment arm and the water pump that i should be able to remove as well. There were a few there when I bought the car and I had to add even more when I spaced it all out to make room for the Cloyes timing cover for my roller cam.
Here is a picture from last year:
Old May 1, 2017 | 10:49 AM
Alan 71's Avatar
Alan 71
HiATL,
The aftermarket lower alternator mounting bracket likely also comes into play with bolt position and belt length.
Regards,
Alan
Old May 1, 2017 | 10:52 AM
AboveTheLogic
I do wonder what happened to all the original stuff from this car. Seems that someone just got rid of it all for no good reason
Old May 1, 2017 | 10:57 AM
Alan 71's Avatar
Alan 71
Hi ATL,
The 'new' part is often described as an 'upgrade' from the original.
Regards,
Alan
Old May 1, 2017 | 11:13 AM
AboveTheLogic
The bracket is not good either, just shiny. The bottom of the alternator doesn't mount properly on it, some hardware is missing there.
KapsSA, what is the extra bracket you have?
Old May 1, 2017 | 12:49 PM
Alan 71's Avatar
Alan 71
Hi ATL,
From your photos I see lot's of 'upgraded' parts…. it may be difficult to determine just what lower alternator mounting bracket might be the best choice at this point.
Here's an example of an original lower bracket…. but I'm in NO way inferring this is what will work for you.
Regards,
Alan
Old May 1, 2017 | 01:33 PM
KapsSA's Avatar
KapsSA
The arm I have is like your wrong one, for 80-82.
Your main mount "looks" correct for 79, maybe original polished and chromed? Or aftermarket. There should be a short sleeve in one of the mounting pivot holes that snugs things up when you tighten the alternator through bolt.
Don't understand the washers??
The adjustment arm that attaches at the water pump should have a bolt with a stud on the end. About a 3/16" spacer and alternator adjusting arm goes under the bolt head/nut against the water pump, smog pump bracket goes on outside of bolt head/nut with a lock washer and nut finishing it off.
I agree a shorter belt would be nice but looks like you have taller valve covers which would make it hard to go much shorter.
To Right vs Wrong Alternator Adjustment Brace
