Insulation / Sound deadening
I finally got the old A/C system out of the car. So now its sitting there nice and naked.
The vintage air unit just arrived, but I'm thinking that before I go down that road, now would be a good time to add some sound deadening and insulation.
In the past I've used fat mat, g-mat, and EZ cool. In every case I found it next to impossible to know if any of these products actually had much (if any) effect on noise and or heat transfer.
That said, the jute insulation (or whatever it is), seems to be rather useless.
Has anyone have and good success stories to share???
Thanks,
Len
You can spend lots of money buying hi-tech products. But, I'm not sure they are any better than what came on the new C3's.
It's been over 10 years and 20K miles since I redid my interior, and it's probably due to get it again. When I do, I will use jute insulation for heat rejection. I will probably put foil layer on it to also reject radiated heat, also. I'll find something for sound deadening that is similar to factory stuff, too.
P.S. Don't worry about heat rejection in the storage area. The exhaust system is too far below to cause any heating problems there...unless you just sit idle for long period of time.
Solution:
Fatmat or similar (and in your case need to scrub out the front panels so the butyl rubber will get a solid hold on the panel.) Single layer for sound in front to back of seats then DOUBLE layer in back
Frost King from Lowes for heat. DOUBLE layer in front to back of seats and single layer in back.
Also for sound put the Fatmat (It is better than Dynamat) on the outer door skin with the door panel removed and window up. Cover as much as you can with the butyl rubber mats. Makes the doors close with a solid feel and much less road noise. While it is apart try to replace the rubber anti rattle sleeves that are on the door lock rods so there is no rattle when you close the door. Might just have to reposition the ones you have in there.
That treatment will last the life of the car with it not being changed with time or compression.
Also with it apart like that it is a perfect time to replace the brake booster. Easy right now and not so easy when it is together. If it is original it is time to replace it.
Solution:
For some reason I wasn't getting notices of replies until today.
Anyway, I have a fat mat like material on order - will also pick up some insulation from Home Depot this week.
There is a thick black tar like material that is around the inside firewall where the heater core was and it extends up and over the front top of the center tunnel.
I presume that black stuff should come out as well???
http://web.archive.org/web/201107110...Instresult.asp
Otherwise every house built would use it. Does claim a higher value IF you have a barrier of air 3/4" between . Air makes an excellent insulator till it moves!!!
I used it on my 73- I taped the seams w/ 3M foil tape to stop the air movement. It does make for a tight fit- as the seat belts/seat are snug.
I drove the car about 3000 miles (one week- Hotrod Power tour) and compared the the year before. There was a difference- from unbearable to bearable but not like a newer car.
I also blocked/shut off BOTH sides of the heater core-as thanks to convection the heater WILL get hot if only one side is stopped as the factory did it. ( just takes a little longer)
On my 71 - I'm taking a little bit different approach- Lizard skin on the interior -Thermo tec's-"Cool it" on the exterior of the car-exhaust heat shielding and really just for looks carbon fiber heat shields...
The 73
The 71
I found like Richard did is that you have to address the heat from the underside.
I used the DEI firewall sheets. It's thick aluminum with glass core. This made most of the difference at my feet.
For the inside I used Vette Nuts kit.
https://www.reflectixinc.com/about-r...bout-r-values/
I have not used Reflectix on my cars but have used it in my house....The reason it is not used in homes routinely is that reflectix is 2X as expensive as conventional insulation not because it does not work well in the right application....
One a C5 I had that had a supercharger and was very hot I had very nice results with the usual Dynamat inside but then one inch of ceramic blanket that blocks up to 3000 degrees. No heat came through but the carpets were a bit fluffed up, didn't notice it but did notice a very cool and quiet car.
I pulled out the interior and put down hushmat or something similar. I then put down reflectix. The cabin is now quieter and cooler.
In addition I redid the AC system and added a hot water shut off valve. I have the C4 blower motor and a pro6ten compresser.
The cabin is now better insulated and I can cool it down too.
No more sweaty calves.
John
About 6 years ago, I did the entire interior in my 69. We cleaned it down to bare fiberglass. I put DynaMat Xtreme from the firewall all the way to the top of the turtle deck. I had a 69 Corvette that made no squeaks or rattles, except for the plastic over the gauges in the center console, which has been fixed now. I installed all the "stock" carpet and insulation on top of that.
Almost 2 years ago, I pulled the motor and trans for a complete rebuild. I added all the insulation/heat reflectors under the floor. The tunnel insulation with each floorboard insulations then the (at least mine were) steel plates on the front and bottom of the floor boards too.
My wife couldn't think about going in the car without full shoes on, and now she wears flip flops (like always) in the car and is very comfortable. She can even go barefooted and not be hot at all.
Like I said, we all do what we think is the best, I'm just sharing what worked for me and our 69. I have headers and full underneath exhaust, not side pipes too.
Great point...
I agree there are many ways to tackle the heat issue and there are many solutions that all will work. The point is with very little real effort and modern materials in conjunction with the OEM carpet parts, these cars can be made VERY comfortable in the heat. Any one who thinks the OEM carpet and insulation was adequate frankly does not understand the magnitude of the improvements that can be made....
