Yikes !! My Holley Fuel Pump is putting out 20 psi !! Now what ??!!
Just installed a new Holley 'Black' series Fuel Pump preset at 14 psi output. Its putting out 20 psi. The regulator at the carb is going crazy bouncing around .
Anyone ever have this happen to them ?? Sounds to me like the Fuel Pump isnt going into internal bypass and is building up too much outlet pressure.
RR
RR
Re: Yikes !! My Holley Fuel Pump is putting out 20 psi !! Now what ??!! (Rumpity Rump)
Time for a pressure regulator! I'm only running about 6 1/2-7 pounds on my 383. Got the Holley Blue pump and regulator.
The Regulator is new too. Its jumping around because i dont think its designed to see 20 psi incoming. The fuel pump starts out displacing 20 psi then after a long while, it will go to 14 . Only then , will the regulator hold steady at 7 psi.
Guess its time to rag on the Holley Tech !
RR
RR
