Jerking/bucking on initial acceleration
Old May 7, 2017 | 10:52 PM
BarryB72's Avatar
BarryB72
Default Jerking/bucking on initial acceleration
72 base engine 4 speed
Manual brakes
Vacuum system functional
Stock carb rebuilt
TCS solenoid functional
Original coil
Original distributor with Breakerless SE ignition
Fuel filter new
Fuel lines/tank new
I thought I forgot how to drive, but it's done it the last couple times I've driven it.
I'll start it, let it idle, tap the accelerator and bring the idle down to 800 rpm.
Leave the driveway, go about 500 feet, stop, turn and if I floor it it will buck and jerk like it would if I repeatedly tap the accelerator in first gear.
I stop, sit a few seconds, put it in gear and floor it and it's perfect the rest of the drive.
It's possible it's progressed from not a strong response, to mild bucking, to more severe bucking the last three times I've driven it. But it's just the first time I floor it.
Something stuck or catching?
Old May 8, 2017 | 11:23 AM
REELAV8R's Avatar
REELAV8R
Manual brakes
Stock carb rebuilt
Original coil
Fuel filter new
Fuel lines/tank new
Sounds like it might just be too cold when you are doing this. The Q-jet has a secondary limiter that won't allow the secondaries to open until the engine/carb warms up a bit.
Old May 8, 2017 | 09:05 PM
BarryB72's Avatar
BarryB72
Thanks.
To Jerking/bucking on initial acceleration
