Door Panel REMOVAL ?
Old Sep 28, 2002 | 01:19 PM
MrBigButt98Conv's Avatar
MrBigButt98Conv
Default Door Panel REMOVAL ?
Help. I am replacing the Interior of my 74. Everything but the door panel is now out. I bought that flat tool that is suppose to slide behind the lock-unlock ****, BUT i can't get it to pop... Any suggestions would be most appreciated
Old Sep 28, 2002 | 01:23 PM
Mack's Avatar
Mack
Default Re: Door Panel REMOVAL ? (MrBigButt98Conv)
It sounds like you're prying the ****. That's not how it works. There's a u-shaped clip behind the lock **** that holds it in place. The tool is used to push the clip out. Then the **** comes off. Is that what you mean?
Old Sep 28, 2002 | 06:38 PM
Mack's Avatar
Mack
Default Re: Door Panel REMOVAL ? (Mack76)
Did you get it off, or had you already tried that?
Old Sep 28, 2002 | 07:17 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
panel popper is what the tool is called. they work great. snapons are my favorites.
To Door Panel REMOVAL ?
