Rotor runout
Old May 15, 2017 | 10:18 AM
croaker's Avatar
croaker
Default Rotor runout
if I take original rotors off do I have to shim them when reinstalling them same orientation?
Old May 15, 2017 | 10:21 AM
Big2Bird's Avatar
Big2Bird
You should not have to at all.
Old May 15, 2017 | 12:24 PM
20mercury's Avatar
20mercury
Default Hi, Croaker!
My 2 cents:
Agree, if you drill out the rivets and reinstall in the exact location, no shims.
I would:
1. Check the runout before you drill out the original rotors and remove.
2. Sounds like you plan to reuse the original rotors, if so, you want to index mark exactly how they were installed to reinstall as original.
Note: Originally, the rotors were first riveted on and then turned on the hub. So if you turn your old rotors off the hub, it is a new ball game. Some purists I know rivet a new rotor on the old hub and then turn and true up as an assembly. I used new rotors and shimmed between the new rotor and hub to get less then .005 runout and that works fine. These are fixed calipers so any runout will pump the calipers.
If your old rotors look decent, like my 68, I would not drill out and remove them. I just cleaned thoroughly with brake cleaner, hand sanded with 80 grit, reinstalled and checked the runout and then new pads.
Hope this helps.
Old May 15, 2017 | 04:23 PM
80-Vette's Avatar
80-Vette
Originally Posted by 20mercury
My 2 cents:
I would:
Hope this helps.
What if you need to replace the emergency brake shoes?
Old May 15, 2017 | 07:35 PM
DUB's Avatar
DUB
That will depend on what the rotor run-out was prior to you removing them.
Do not know if you are asking about front or rear rotors. It kinda does make a difference.
DUB
Old May 15, 2017 | 09:33 PM
croaker's Avatar
croaker
Dub rear.
20 Merc. May have to pull to check brake shoes.
Old May 16, 2017 | 06:25 PM
DUB's Avatar
DUB
'croaker'
ASSUMING that the car has not curbed the rear wheels...thus causing the spindle to be off. I would say that as long as you keep the rotors on the side that you took them off...and make SURE that the spindle surface is CLEAN AS A WHISTLE and so is the rotor where the two contact...you should be OK.
But...once again...that is assuming that they are fine...which is why I would check them before I take them off.
DUB
Old May 16, 2017 | 08:47 PM
croaker's Avatar
croaker
Thanks for the replys guys
Old May 16, 2017 | 09:36 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by DUB
'croaker'
DUB
Excellent advice!
Thanks for the post DUB!
GUSTO
To Rotor runout
