Air Cleaner Question
Old May 16, 2017 | 04:55 PM
CHRISP73's Avatar
CHRISP73
Default Air Cleaner Question
Is anyone aware of a low profile air cleaner that will fit under a stock hood on a 73? The edelbrock manifold that I am using is a little higher than stock.
Old May 17, 2017 | 11:27 AM
MelWff's Avatar
MelWff
see if this helps, there are others if you use the advanced search feature
https://www.corvetteforum.com/forums...r-cleaner.html
Old May 18, 2017 | 09:34 AM
GUSTO14's Avatar
GUSTO14
You mention you're using an Edelbrock manifold, but what carburetor are you using?
Are you wanting to stay with the original cold air package?
Some of the drop-base, open element, air cleaners from the late 60's (Corvettes) will give you additional room. You'll just need to get a base that matches the carburetor you are using.
Good luck... GUSTO
To Air Cleaner Question
