1976 c3 ride height? 4x4?
Old May 16, 2017 | 10:54 PM
slyder383's Avatar
slyder383
6th Gear
Default 1976 c3 ride height? 4x4?
Hi corvette gurus. I'm an old MOPAR lover with a new project for my father. His 76 c3 is all jacked up. Seriously, looks like a four wheel drive. The car has been sitting for a few years, yet runs good. He has lung cancer and I want to get the car right for him. I apologize I dont know how to post pics. The rear is 6 inches from the top of the tire to the bottom of the fender. The front is 4 inches from the top of the tire to the bottom of the fender. There are 9 leafs in the rear pack, all are curved. This is a strange car. It has 3 to 4 different paint jobs under the black, but I dont see any crash damage. I cant find a fender tag. I have many more pics I can post if it would help. And I appreciate any help I can get. Thanks, from Tim.
Old May 17, 2017 | 12:22 AM
rcread's Avatar
rcread
The rear may be dropped by loosening the nuts at the ends of the leaf spring. If you are at the end of the bolt and still too high, get longer bolts. What size are the front tires? They should be about 27.1" in diameter.
Old May 17, 2017 | 05:29 AM
bashcraft's Avatar
bashcraft
Have the springs been replaced?
Old May 17, 2017 | 07:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by slyder383
...I cant find a fender tag...
There isn't one. The trim tag is on the driver's door hinge post and visible when you open the door. The VIN tag is on the driver's windshield post and visible from outside the car.
Old May 17, 2017 | 11:09 PM
slyder383's Avatar
slyder383
6th Gear
I dont know whats going on with this car. It has four different colors under the black. I think it has been pieced together. Seriously, maybe a salvage? I have new spring end bushings and bolts from Ric's, but I dont think there is enough adjustment to lower it correctly. And the front will still be way high. Front tires are p215/60R15. Rear are P255/60R15. The rear is 4 inches from top of the tire to the fender lip. Front is 4 and 1/8 inch from top of tire to fender lip.
Looking at some of your pics of spring pack's has me really confused. This one has 9 leafs, all curved down? No straight/flat leafs.
Old May 18, 2017 | 12:28 AM
Sunracer's Avatar
Sunracer
Wrong tires for a start. Are the shocks frozen? Was it stored on a lift? Pull the shocks. Does it settle after being driven up and down over a driveway slope?
Old May 18, 2017 | 01:19 PM
Richard Daugird's Avatar
Richard Daugird
Four paint jobs on a 40 year old car isn't so strange. My '74 had up to FIFTEEN paint jobs in places when we stripped it to bare glass.
Old May 18, 2017 | 01:21 PM
chazde3's Avatar
chazde3
I don't feel so bad now about the 3 my '68 had lol
Old May 18, 2017 | 01:56 PM
slyder383's Avatar
slyder383
6th Gear
I have new shocks for the rear, they are 1.5 inches too short. The old shocks are longer and shot. that 1st pick is with shocks off sitting on springs, it is settled as much as it will.
Old May 18, 2017 | 07:45 PM
slyder383's Avatar
slyder383
6th Gear
I just got home and got it on the lift. Is it possible someone torqued the suspension bolts down with the car off the ground? I'm going to soak all the susp bolts down, loosen them and set the car back down to see what it does. If it sets down i will let you know.
Old May 19, 2017 | 02:17 AM
Richard Daugird
Couldn't hurt but don't expect a miracle.
Old May 19, 2017 | 08:25 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The front tire looks a little smaller in diameter with could contribute to the optical illusion, but it does look high. Like others have said it may need to settle. Just rolling it back and forth may not work, you need to go for a spirited drive.
When I bought my '71 it was stored on jack stands for 31 years. It too looked a bit high (especially in the back), but I changed the front springs to VanSteel big block 550lb lowering springs, and longer bolts in the rear spring. Now it sits nice, even with a slightly smaller tire diameter on all 4. They are 265/50R15. Don't mind the paint (or lack of), its still a work in progress.
Before:
Now:
Old Jun 16, 2017 | 10:11 PM
slyder383's Avatar
slyder383
6th Gear
Update. I replaced all the rear bushings. Took the rear springs out and flipped them. Installed new spring links and bushings, 2in over rear shock's, and I'm done with the suspension for now. It's still high. New calipers, pads, shoes and hardware done. Thanks for all the advice. I'm on to the steering next with a new thread.
To 1976 c3 ride height? 4x4?
