Weak starts: battery or starter?
Old Sep 28, 2002 | 07:30 PM
VetticusSupersonicus's Avatar
Default Weak starts: battery or starter?
I've been having some trouble getting my car started lately. Before, it would crank hard when it was cold and fire up right away, then when the engine was warm it would take about 4 or 5 seconds before it would catch. (It felt like the starter was cranking a lot slower. Is this "heat soak"?) Now, a little while after installing a new stereo and running a line directly to the battery, the starter is cranking slower than ever and I'm starting to have a bit of trouble even in the cold.
What could be the problem? I was considering installing a newer starter anyway to fix this nonsense, but would that cure the problem?
Thanks for the help.
:cheers:
Old Sep 28, 2002 | 08:27 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Weak starts: battery or starter? (VetticusSupersonicus)
how old is the battery? is it a quality brand?
Old Sep 28, 2002 | 08:56 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Weak starts: battery or starter? (Markm10431)
sounds like the battery
Old Sep 28, 2002 | 10:42 PM
Corvette Cowboy
Default Re: Weak starts: battery or starter? (PrarieShark)
Sounds like you need a battery. Before you replace it, get it load tested. of course, if you want to replace the starter anyway, go ahead.
Old Sep 28, 2002 | 11:50 PM
Thanks! I'll take it down to the Canadian Tire tomorrow to have it tested. It's a fairly cheap model that should probably be replaced anyway.
:cheers:
To Weak starts: battery or starter?
