Seat Swap
Old May 17, 2017 | 08:04 PM
1moore522's Avatar
1moore522
Default Seat Swap
I have a 73 Vette and want to swap out the seats for later model seats that come in the 78 thru 82. Can they be swapped out using the existing mount bolt holes?
Old May 17, 2017 | 08:14 PM
'75's Avatar
'75
Yes they mount the same. I have a friend with a nice set of black leather 79 seats. Pm if interested.
Old May 17, 2017 | 08:56 PM
dmruschell's Avatar
dmruschell
The front mount holes are the same, but the rear mounting holes may be in a different position. Chevrolet changed them every few years from 68-77. I just installed 79 seats in a 75 and had to customize the rear mounting a bit.
Old May 17, 2017 | 09:02 PM
'75's Avatar
'75
I was thinking the seats mounted the same to the sliders, use the original slides.
Old May 17, 2017 | 10:18 PM
dmruschell's Avatar
dmruschell
I've seen people say that. I considered that, but didn't try it because the adjustment levers looked different enough that I didn't think the adjustment lever would fit through the slot in the later style seats. I could be wrong, since I didn't actually try it.
Old May 17, 2017 | 11:39 PM
trw's Avatar
trw
I switched mine using the 73 slides. But used longer bolts in the front and tube spacers (about inch or 1 1/2) to tilt the seat back a bit.
Other than that bolt in.
Hope it helps.
Old May 18, 2017 | 07:21 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Use your 73 seat tracks on the 79-82 seats.
Old May 18, 2017 | 10:37 AM
SteveG75's Avatar
SteveG75
Hope it helps.
Used my '75 tracks to put later model seats in my car. Made spacers for the front that matched the height of the stock '81 tracks. For the adjustment lever, just remove the bottom part of the slot. Totally invisible and works great.
Here is a pic with my new seat covers. I have since repainted the parking brake console for a better match.
Old May 19, 2017 | 10:16 PM
gjohnson's Avatar
gjohnson
80 seats in my 76.Direct bolt in on pass side but drivers side had a tall set of rails so I just bought a set like the pass side ones.
To Seat Swap
