68 427 oil line kits
Im looking for a 68 427 copper oil line kit. All i see offered are the plastic oil line kits. Does anyone know about a 68 copper or stainless Steel oil line kit and where to buy it ? Thanks
Just buy a el cheapo plastic kit and use the ferrels on 1/8 copper line. It should be available at a good hardware store or online. Personally I prefer stainless hose as it seems to be more resistant to vibration and abrasion.
Is a 68 different than a 69? Paragon has them for 69-73.
https://www.paragoncorvette.com/p-35...-assembly.aspx
I did think of that. But was just hoping they sold copper or stainless steel oil kits for a 68.
Paragon Number: 2134K
GM Part Number: 3961560
Oil pressure line assembly, metal and plastic, 427 and 454. Includes 34 fitting. Also fits Camaro.
Years 1969 - 1973
Packaging: Kit
Condition: New
Type: Stock
MikesRed68 (05-19-2017)
I just changed all of mine to -4AN lines. Replaced the fittings at the block and gauge with the appropriate -4 to 1/8NPT, used a short line from the block to a bulkhead fitting, and then another line to the gauge. Steel braided, 3000PSI burst strength and Teflon lined. No more worry about the nylon getting melted, the copper cracking, or the steel leaking. Gauge pulses a bit, but responds quickly too.
