Cannot install driver's side wiper arm
Old May 19, 2017 | 04:05 PM
kansas123's Avatar
kansas123
Default Cannot install driver's side wiper arm
Okay here's the deal. I have been working on this wiper system since I had someone replace the actuator. Long story short, through reading posts and AIM, I got everything working perfectly (actuator was bad and the safety switch was bad). The problem now is the post that the driver's side arm mounts on is clocked wrong. Looking straight down on it, the key is at about 8 o'clock and the keyway on the arm is at about 12 o'clock. Is there an adjustment for that, like in the middle near the wiper motor? I have no idea why it is not in the correct orientation....Thanks.
Old May 19, 2017 | 04:26 PM
Alan 71's Avatar
Alan 71
Hi K,
Yes, the transmission arms can be adjusted individually in the center at the wiper motor connection.
Regards.
Alan
You can see the slots for the adjustment.
I don't know if there will be enough adjustment though. Are you SURE you have a left wiper arm?
Old May 19, 2017 | 04:28 PM
TimAT's Avatar
TimAT
Is it possible to rotate the left (drivers") side shaft by flipping the drive arm to the other side? Just asking, I don't have access to my copy of the AIM or the FSM..If the lever off the bottom of the shaft is pointing up, make it point down. Would that bring the key to the correct spot?
Old May 19, 2017 | 04:42 PM
kansas123's Avatar
kansas123
Originally Posted by Alan 71
Hi K,
Regards.
Alan
Thanks, I noticed slots for the pass side but didn't see any for the driver's. I'll give it a go.
I tried seeing if the arm would fit on the other side but it would not because of the configuration of the arm.
Old May 19, 2017 | 05:17 PM
kansas123's Avatar
kansas123
Not sure I'm following you....
Old May 19, 2017 | 06:07 PM
TimAT's Avatar
TimAT
The last picture Alan posted shows the arm pointing about 5:30 if you're looking straight at it. If that arm was 180* from there, would it put the keyway in the proper spot?
Old May 19, 2017 | 06:09 PM
kansas123's Avatar
kansas123
Alan, yeah there isn't near enough movement there to line things up. I'm gonna look at those arms again, make sure. Cause they came off there, they gotta fit. I used to have a leak in that cowling and had a guy seal it, I don't think he removed the wiper wotks, so every thing should still be the same...
Old May 19, 2017 | 06:49 PM
kansas123's Avatar
kansas123
I am so hosed, I just don't see any what I am gonna get around this, except maybe grind the key off. But that's just not right. Look at it tomorrow I guess, maybe something will make itself known.
Old May 19, 2017 | 08:31 PM
kansas123's Avatar
kansas123
Tim, here is a pic of my post taken facing toward windshield. If my post was orientated like Alan's, it would work. I just cannot figure out how this got turned or misaligned. You'd think there was an easy way to adjust it....
the black arrow shows where the key is; the white is an approximate point where it should be to work correctly.
Old May 19, 2017 | 09:52 PM
TimAT's Avatar
TimAT
IT looks like the drive rod needs to be on the other side of the shaft. If you disconnect the rod from the motor end, can you move it so the lever on the shaft is on the bottom? Basically the shaft 180* from where it is now..
Looking at Alan's last picture, it appears the key on the shaft is pointing inboard and the lever on the shaft is toward the bottom..
Old May 20, 2017 | 07:09 AM
Alan 71's Avatar
Alan 71
Hi,
Here's a photo showing the whole left side wiper transmission.
I agree that your transmission tab appears to be off by almost 180 degrees.
Yours is pointing 'rearward' while it should be pointing 'foreward'.
Regards,
Alan
Old May 20, 2017 | 09:47 AM
kansas123's Avatar
kansas123
Good catch! I'll attend to it today.
Old May 20, 2017 | 11:15 AM
3X2's Avatar
3X2
Looking at Alan's and Kansas pictures, it looks to me the lever on Alans is at 5 o'clock and on Kansas pointing towards 1 o'clock. In other words the rod connecting the motor to the rod is on top rather than on the bottom of the wiper pivot. Unhook the rod from the motor and rotate so the rod is on the bottom and reconnect????.
Old May 20, 2017 | 03:02 PM
kansas123's Avatar
kansas123
Moving the rod was exactly what was needed. The one who did the sealing in that cowling area put it back together wrong. That person made a lot of other mistakes, very disappoint in him. But at least he did fix that annoying leak.
Thanks for all the advice, have a great day.
Old May 20, 2017 | 03:09 PM
Alan 71's Avatar
Alan 71
Hi k,
GREAT!
Regards,
Alan
To Cannot install driver's side wiper arm
