Fuel Injection
Old May 21, 2017 | 06:14 PM
pawpaws toy's Avatar
pawpaws toy
Default Fuel Injection
Wanting to install FiTech injection. Could I feed an external FI pump with the existing mechanical pump? This is on 1980 350.
Old May 21, 2017 | 07:04 PM
DUB's Avatar
DUB
I would not...something about supplying an electric pump with a mechanical pump just makes my head spin.
DUB
Old May 21, 2017 | 07:31 PM
mrvette's Avatar
mrvette
On my '72 I put the pump in the back on a frame rail.....gravity fed though the filter from the tank pickup.....I used the stock lines to/from the front.....
I dunno about on your tank, some changes in there.....
Old May 21, 2017 | 07:54 PM
'75's Avatar
'75
82 had fuel injection and has the same tank as the 80, so getting an 82 sender and in tank pump may be the answer, or the 82 sender with another in-tank pump.
Old May 30, 2017 | 05:36 PM
SpeedRacerMach's Avatar
SpeedRacerMach
Yes. You could use the FiTech Command Center (aux fuel sump) or an Edelbrock EFI Sump Fuel Kit.
https://www.corvetteforum.com/forums...fi-review.html
http://www.edelbrock.com/automotive/...uel-kits.shtml
Old May 30, 2017 | 07:42 PM
Tecdiverfl's Avatar
Tecdiverfl
Many people that have used the Fitech FCC have had problems. Not the best choice
Old May 30, 2017 | 09:30 PM
lionelhutz's Avatar
lionelhutz
This makes it easy. Use a Holley HydraMat if you're concerned about starving the pickup. They make one that installs directly onto the base of a typical in tank pump.
To Fuel Injection
