A Tale of 3 "NEW" Ignition Coils
I've been chasing a random and extremely intermittent engine popping under hard acceleration in the 3000 to 4000 rpm range ever since I installed a new intake manifold and MSD Blaster 2 coil about a year ago. Drove it all summer and fall until I started on my winter project of replacing the original heads with some Edelbrock aluminum heads. Finally got it running and running good about a month ago, hoping in some way the old heads were contributing in some way to the random popping. No such luck. Rechecked timing and dwell, all good. Searching this and other forums, found others having the same issue and discovered ignition coils breaking down. So, I bought 3 new coils. A new MSD, an Acell,(matched the color of my C3), and a Delco U505. Installed the Acell this morning, no start. Checked connections, still no start. No problem, I have the NEW MSD. Installed that one, STILL no start. Installed the old MSD, fired right up. OK, well I can't drive and test it out for the popping with THAT one, because that's the one that I suspect is causing the problem. Take that one out and put in the new stock Delco unit and go for a test drive BINGO, no more popping! Just nice smooth pulling power thru the entire RPM range. Now, just need to regap the plugs back to .035 and enjoy driving it. AND, I'll be returning the "NEW" coils tomorrow.
Good old stock Delco coils are still the best. ZERO gain from "performance" coils. HEI is the only upgrade, but no performance gain, just reliability from point free operation.
Yep. The latest batch of Blaster 2 coils are absolute crap. They leak, they fail, they get hot, they cause headaches.
Is it possible that the new after market coils require a full 12 volts unlike the original which uses the reduced voltage supplied by the ignition resistor wire on the early C3's?
That doesn't make sense because the engine ran pretty good with the MSD Blaster 2 that I installed last year. Just the random popping. I'm just AMAZED that TWO BRAND NEW COILS from TWO DIFFERENT COMPANIES were defective RIGHT OUT OF THE BOX! But, perhaps I expect too much. After all, it's 2017, not 1977.
There is an ignition stickey at the top that will explain it in greater detail.
CanadaGrant (05-22-2017)
Cruise-In IX Veteran
I had a lot of issues with coils until I put in the MSD high vibration one. I belive they are built in a different place from the other blaster 2 coils. They use epoxy so you dont have to worry about oil leaking out.
Been there, done that. Aftermarket coil installed came with occasional intermittent engine misfiring. Put the original antique Delco coil back in and never had a hiccup after that. The HEI is a solid piece that just needs a recurve. NEVER AGAIN!
C3 of Year Finalist (track prepared) 2019
I had one of those fail about 2 weeks after install last year. I put the 15+ year old blaster 2 (that I replaced purely as a preemptive measure given its age) back in and all was good. I swapped the warranty replacement high vibration coil into the car about a month and a half back and haven't driven it a lot since, but last time I drove it it was breaking up at higher rpm and load. I'd put that down to running rich due to an exhaust leak (which it is), but perhaps I should check swapping the old coil back in...
I was looking at LS coils and aftermarket LS ignition coils and the aftermarket ones still have huge quality control issues, until you get into the really expensive ones made like 20+ lbs of boost the GM Delcos seem to be the way to go.
Went with a set of LS3 generation truck coil takeoffs from Ebay: $125 for 8 coils, bracket, and wiring harness- no plug wires & lots of rust.
Adam
Adam
Not all ignition coils àre created equal the super magnetic core makes superior. I bought these back when they were made by crane cams. FAST seems to have bought the product because they saw the superior design
https://www.summitracing.com/parts/fst-730-0291
Aftermarket manufacturers don't have to adhere to the same stringent specs as the OEMs so their reliability is all over the map.
Unless the OEM parts can't support your particular build, I'd stick with them.
Just my .02
Just my .02
What is a super magnetic core?
V=I*R
When the Crane Cams ignition coils first came out one of the car rags did an article on the use of Super Strong Rare Earth Neodymium Magnets. it vastly decreases charge and discharge time. Less heat production....... they aren't even oil filled to conduct the heat away. Just a great compact coil.
They work really well in high powered multi spark ignition systems or even your mild stock motor.
Before the points close it will be 12v~ once the points close and a load is produced the voltage divider circuit functions and there is an instant drop in voltage... this is how a voltage divider circuit works
I understand how you see this...
I was an electricteonics engineer for well over 20 years
EE CSUN
EE CSUN
EE CSUN
EE CSUN
My Sun machine has an ammeter and a volt meter, and a variable ballast resistor. I close the points and set the resistor to 4 amperes.
If I run the distributor, the amperage drops to 2 amperes, because the meter can't keep up, and reads an average of 2 amperes, but it's really pulses of 4 amperes.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
EE CSUN
EE CSUN
The ballast resistor limits the peak current through the coil and points, but it does not limit the peak voltage that the coil and points see.
EE UI
