Horn relay
May 22, 2017 | 02:47 PM
Horn relay
1968 convertible where is the horn relay located?
May 22, 2017 | 02:54 PM
Hi h,
It's mounted to the rear of the driver's side apron just below the hood surround.
Regards,
Alan
May 22, 2017 | 05:35 PM
2018 C3 of Year Finalist
Quote:
Originally Posted by
Alan 71
Hi h,
Regards,
Alan
Alan , hope I am not butting in here but where is your vacuum tank?
I just changed my horn relay ,what a bear the vacuum tank is right there.
May 23, 2017 | 12:18 AM
Alan 71
Hi h,
Regards,
Alan
Is the relay in the same position on a 73?
May 23, 2017 | 06:34 AM
Hi JB,
Yes, the vacuum storage tank is there.
It's difficult to see because it's dark under the hood surround.
You can JUST see the corner of it.
Regards,
Alan
May 23, 2017 | 06:42 AM
Hi 73TV,
I believe the horn relay is in the same location for the 73 model year.
Member Tooch1 will know for sure.
Regards,
Alan
I just took a look at the 73 AIM and it appears the horn relay is in the same location as 68-72 cars.
May 23, 2017 | 02:43 PM
Alan is correct. This is the relay on my 73.
Donnie
May 23, 2017 | 08:38 PM
That bolt or stud that hold the relay on is a bear to get loose
The wires aren't to bad but that stud is close to impossible!
