Inside View- Gear Banging Fun!
Old May 25, 2017 | 12:45 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Inside View- Gear Banging Fun!
Here's a new video I found from my last track excursion. There was a guy who came up and asked to put a Go-Pro inside....but I never got his name and didn't know what happened to the video.
So you get a little inside "gear banging" fun ride!! This is a run through in 4th gear....about 7750 RPM at the line!
JIM
Old May 25, 2017 | 01:55 AM
Les's Avatar
Les
Jim, a lot of words come to mind- many of which I can't say here. Wicked, violent, and inspirational are some that I can use. You're very quick with the shifter! I'm surprised by how quiet the turbos make it, considering the power level. Many thanks for sharing with us. What a ride! Oh, but next time latch your hood.
Old May 25, 2017 | 01:57 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Nice .Thanks for sharing Jim.
Old May 25, 2017 | 06:35 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
That's awesome!!
Old May 25, 2017 | 07:19 AM
blue by you's Avatar
blue by you
Nice
Old May 25, 2017 | 07:56 AM
Big Block Dave's Avatar
Big Block Dave
Thanks for the ride along!
Old May 25, 2017 | 09:34 AM
73BBVette's Avatar
73BBVette
Awesome.....
Old May 25, 2017 | 10:20 AM
theandies's Avatar
theandies
Always fun watching you and your car perform. Thanks!
Old May 25, 2017 | 07:56 PM
zebebad's Avatar
zebebad
The hood unlatched and up in the air in the rear was done on purpose to allow air to come in like a cowl induction hood old trick the racers used like on the 61-64 chevys at the drag strips racers like Grumpy jenkin's and Hayden Proffitt's 63 chevy's always had this done on their drag race Impala's .
Old May 26, 2017 | 11:00 PM
427Hotrod's Avatar
427Hotrod
Thanks guys!!
I started installing hood latch extensions at the track when I ran a carb. I installed a 1" spacer and needed some room plus it got some fresh air moving.
C-2's have a bad reputation for handling at high speeds...but mine always seemed to drive fine. I figured the open hood must be relieving some pressure and helping keep the nose down. So since it always worked...I've kept doing it though with the turbo setup I really don't need to for hood clearance.
I've promised everyone that the next time I'm at the track I'll leave the extensions off and see how it drives.
JIM
Old May 27, 2017 | 12:57 AM
Les's Avatar
Les
Originally Posted by 427Hotrod
Thanks guys!!
JIM
I knew you ran with your hood that way on purpose- just giving you a bad time. Now you have me curious about what will happen when you keep it closed at high speed. Be safe!
Old May 27, 2017 | 02:40 PM
Jeff k's Avatar
Jeff k
Nice video! Vettes are well represented at the track! Makes good company for our Camaro here at beech bend this weekend.
keep on pulling gears!
Jeff
Old May 28, 2017 | 12:13 AM
427Hotrod's Avatar
427Hotrod
Beech Bend is one of my favorite tracks!! Great looking rides right there!
I wish the Forum still held events in BG...it was a great time. We'd rent the track on Thursday each year and have a blast!
JIM
Old May 28, 2017 | 10:52 PM
theandies's Avatar
theandies
You need to see the picture of him at speed with the soft top up. That's a great picture.
Old May 29, 2017 | 01:50 AM
427Hotrod's Avatar
427Hotrod
This one??
Old May 29, 2017 | 02:31 AM
AboveTheLogic's Avatar
AboveTheLogic
Interesting to see how the rear tires camber in when the turbos really spool up and the rear end squats.
You can really see it in the video if you are looking for it.
Old May 29, 2017 | 02:47 AM
theandies's Avatar
theandies
This one??
AWESOME!
To Inside View- Gear Banging Fun!
Old May 29, 2017 | 04:01 AM
SB64's Avatar
SB64
JIM
https://www.youtube.com/watch?v=jyVcyIog5BY
Thanks Jim, it sure brought back some fun memories I had racing my 65 fuelie out on Long Island NY back in the day. What a last................
I wonder what hie ET was.
RVZIO
Old May 29, 2017 | 12:49 PM
427Hotrod's Avatar
427Hotrod
It ran a 9.19@157.83.
It would hook initially and then spin down track. Slicks were 7 years old. Have new ones now...heading back ASAP to get an 8 sec timeslip!
I was trying different things to get it to make a decent ET. That was a low RPM launch and it had to pull back hard...but it did OK. I'll be able to come out harder next time. It's got MPH to run deep 8's as it is...just need to first part to improve. Or I can turn up the power and run it harder out the back door if I have to!
JIM
Old May 29, 2017 | 04:09 PM
SB64's Avatar
SB64
JIM
Jim back in the day(69) I was running 7:93 in the 1/8 and 12.2's in the 1/4 and I thought those were good times. Yours are of the charts! I was running 5:38's and 18" slicks. I was not allowed to radius the wheel wells and back then you had to adlib. So I ran dodge dart air shocks in the rear to clear the tires. It was a great time for me. Love the video.................................
RVZIO
