starting problem
Old May 26, 2017 | 09:49 PM
outsider66's Avatar
outsider66
4th Gear
Default starting problem
I have a 76 Stingray. It was starting fine a few days ago and now nothing, I turn the key and I hear a click. The battery is good, starter is good, all fuses I can find are good. Yesterday I changed the oil, valve cover gaskets, spark plugs and now nothing. Yes it's in park. I have tried everything I can think of and still nothing. Any help would be great.
Old May 27, 2017 | 07:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
try putting it in nuetral. If that doesnt work try tapping the starter solenoid with a small hammer or the handle of a screw driver. if it starts you need a starter solenoid, most replace the whole starter
Old May 27, 2017 | 07:44 AM
vbgod1's Avatar
vbgod1
Rule of thumb, if it clicks, you are getting power to solenoid and its mechanically activating, but power is not coming out and going to starter motor, or motor is bad. Try tapping with a hammer like RR said.
Old May 27, 2017 | 08:47 AM
dembo's Avatar
dembo
Had the same issue for a while now, don't laugh but to get it started it helped rocking the car back and forth by the wheel while in park. I guess it has the same effect as tapping the motor.
The actual issue in my case was a battery disconnect switch. Took it off, retightened the battery cable bolts and it seems to be resolved.
Nick
Old May 28, 2017 | 08:24 AM
biackbenz's Avatar
biackbenz
Check your ground wire connections first. Disconnect the battery first. There is a ground connection on the starter a nd another ground from the frame to the engine block. Remove these a nd polish them with sand paper or wire brush till clean. Starter needs a good ground. Easy to do, won't cost anything a nd most likely will solve tor issue. Good luck.
Old May 29, 2017 | 04:25 PM
Rescue Rogers
theres also a ground connection from the battery to the frame, Atleast on my 68 thats how we roll, check the battery posts too
To starting problem
