Neat tool to determine wheel backspace, offset, etc.
It's adjustable for 14" to 20" diameter tires and 14" wide wheels.
I am dissappointed that we are not hearing more about your test rides. I for one would love to hear more.
It looks like I will be able to run a 315/35ZR18, 10.5" or 11.0" wide, 5.5" or 6.0" backset wheel, on the back with the tire only outside of the body line by about 1/4"-1/2" , judged with a bobline, and a 275/35ZR18 up front. I run offset trailing arms and shortened VP&P dual mount leaf spring in back. I might have to lose the factory style rear sway bar, but if performance decreases I will go with a stock car style splined lever arm sway bar.
Norval,
It would be an easy tool to make, but when I bought it, I didn't have the fabrication machinery in my garage I have now.
I've only put about 300 miles on the car with the TT setup, and right now the tranny is out of it. I'm basically finishing up that last 1%, and it goes for paint at the end of October. Just stuff that I rushed through just to get the engine dynoed or the car at least running, that I am going back and doing it the way I intended. I've only run it on the street with about 5# of boost and it is out of hand. I need to get more tire under it and do somehting about the rear end. Right now, I've go all of Tom's differentials forged, 30 spline yokes and spindles and stuff, but it still scares me to think what would happen if I really got on it and one of the ujoints broke. I need to fab or buy some halfshaft loops before I feel confident in beating on it. I had a ujoint break a couple fo years ago, when I was just running a 450hp/500ft lbs 383, and even at 5mph the damage was eye-opening.
I ran loops on both ends of my half shafts for years but with the 6 link I had to take them off. Guess I should reconsider but I do not intend to go back to slicks.
I am not sorry I installed the 6 link and would recommend it to anyone.
Anyway good luck with the car. You will never be finished. I have been working on mine for 14 years now and continually try to improve it.
I think you are like me in that we enjoy working on them almost as much as driving them. I look forward to the winter where I can tear it apart and start improving.
Have a nice day Monty
Is that a pic of the outer spindles you made? It looks pretty stout, any possibility of making more ;)!
All weekend I thought about asking forum members if they would consider chipping in and buying one of these tools for the forum's use, but you already have one. Wouldn't it be great if members started saving at least one of their used/worn tires in the larger sizes and widths to pass around to other forum members to try? It does cost to get rid of tires now and paying just the shipping charges to try a tire size shure beats the price of a new one that turns out not to suite you. Hell, I'd even store them and ship one, once I received a money order. I live in central Arkansas, pretty much the center of the U.S. Toss this around. Let me know what ya'll think.
http://forums.corvetteforum.com/zerothread?id=302269
did not follow it through to the end so have no idea where it stands.
I don't do custom work anymore because I can't control the installation and don't want to be responsible for any accidents. I still do some work for the local speed shops but I install what I make.
I had my son spline the axles. He can cut any automotive spline up to RC50.
Next year I hope to have my own complete machine shop. An old friend is retiring and promises to sell me his shop. I will move all the equipment to my shop and be mainly self sufficent.
As for the tire back spacing tool a piece of angle iron with holes to fit over 2 studs and some 1/4 threaded rod with nuts can make a good gage for checking clearances for tires and rims.
With the angle iron over 2 wheel studs and a length of threaded rod equal to the rim width you want to try and the proper hole in the angle iron you can adjust it to the most convenient backshacing .
Another piece can be used for sectional width.
waterloo huh, im originally from Sault St. Marie (visit twice a year to see family), then moved to Detroit but now live in the much, much, warmer North Carolina,,,,,,
[Modified by Titanium Rat, 7:54 PM 10/1/2002]
Thank you
Centerline rims and I would guess most others measure the 11 inches from bead to tire bead. So a caliper on the outside edges would read more like something over 11.5 then add on the section width of the tire and you might have more than 1/2 inch bulge inboard.
I'll measure my clearance from tire sidewall to the frame tonight
I would think that 4.5 inch back spacing would be max with decent tires. If you go to really wide rims the sectional width is pulled to the outside and maybe larger offsets can be used but the tire then sticks past the fenderlip. With proper everything 305's can be fit under the wheel well without sticking out.
You guys were right. I was reading the tool's measurement at the wrong location, plus you have to subtract 1/2" from the reading, due to the thickness of the mounting plate. It looks like 4 3/4" backspace is the maximum I can run with the tire that I want, a 315/35ZR18 in the back. Measureing with a bob weight and tape measure a 315 tire would stick out about 1/4", barely noticeable.
Right now I can stick my fingers between the closest point which is the trailing arms and the sidewalls of my 315's
My next buy is 11 or 12 inch 18's for the rear :seeya
