Steering wheel height
Old Jun 4, 2017 | 04:49 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Default Steering wheel height
During the process of realigning the drivers door [note: the drivers side lower dash pad must be removed for access to upper hinge bolts] I noted that the steer column support bracket [part #3945326] and the iron casting [part# 3945325] are both slotted, to allow both lateral and vertical height adjustments. A picture of this can be found on page H218 of a 1968 AIM or in the steering section of different years. By moving the support [3945326] forward I increased the distance between the seat and the steer wheel by 1 1/2 inches. I moved the support about half way up the slot and this raised the column up to the lower dash pad. The 2 bolts that secure the column to firewall must be loosened up, they are slotted also. Sure helps getting in and out. The 14" steering wheel I use is now level with upper dash pad. T
