Steering wheel column shaft length
Old Jun 6, 2017 | 10:38 AM
jwappes's Avatar
jwappes
Default Steering wheel column shaft length
Need diagram showing measurements for lower steering column shaft length for a 70 corvette with a tilt steering column
Old Jun 7, 2017 | 08:05 AM
Alan 71's Avatar
Alan 71
Hi jwa,
I don't have a dimension for the length of the column.
Might this photo help?
You can see how much the column extends into the rag joint and the position of the rag joint on the steering box.
Regards,
Alan
Old Jun 7, 2017 | 08:35 AM
jwappes's Avatar
jwappes
Thank, this will help. The rebuilt colunm I purchased was collapsed when I received it,probably during handling in shipping.
Old Jun 8, 2017 | 07:20 PM
69ttop502's Avatar
69ttop502
For a 69 anyway, 4.75 inches should be sticking out from the bearing collar. Not sure if it the same through all C3 years.
Old Jun 9, 2017 | 07:53 PM
Jim Shea's Avatar
Jim Shea
1969 thru 1976 Corvette T&T columns should have 4.7 inches of steering shaft sticking out from the lower bearing face.
Jim
Old Jun 9, 2017 | 08:12 PM
jwappes's Avatar
jwappes
I need the total length of the lower shaft and the points front which they are measured front.
Old Jun 10, 2017 | 06:53 AM
Alan 71's Avatar
Alan 71
Hi jw,
I may be mistaken but I believe the dimensions 69 and JS gave are from this point.
Regards,
Alan
Old Jun 10, 2017 | 08:53 AM
jwappes's Avatar
jwappes
We are still confused, the measurement and measuring points is when the steering column is apart the lower shaft is out of the housing.
Old Jun 10, 2017 | 09:50 AM
Alan 71's Avatar
Alan 71
Hi jw,
Sorry, I thought you were asking about the dimension of the exposed shaft when it's not in a collapsed condition.
Perhaps Jim can answer your question.
Regards,
Alan
To Steering wheel column shaft length
