Loose power steering pump pulley
Old Jun 9, 2017 | 03:48 PM
carriljc's Avatar
carriljc
Default No special tools required...
Make sure you inspect the pump shaft to ensure it is not worn.
When you get your new pulley, line up the key and keyway, push it on, then snug her down with the nut.
Originally Posted by Mpls Funk
Do you expect that I will need a special tool to put the pulley on? I know in other years they are a press-fit and as such you need a special tool to put on. Are these a bit more loose since they rely on the key? Can I put it on by hand and then snug the end nut up? I'm trying to do this with the pump still on the car...and if so, there isn't room for that tool down in there!
Old Jun 9, 2017 | 09:13 PM
lionelhutz's Avatar
lionelhutz
No, you should be able to push it onto the shaft by hand but it should fit snugly once it's on the shaft all the way.
Old Jun 28, 2017 | 01:16 PM
carriljc's Avatar
carriljc
So? How did it turn out?
Old Jul 1, 2017 | 12:54 AM
Mpls Funk's Avatar
Mpls Funk
Hey guys - just got back to it tonight. The new pulley went on very easily. I did find the threads on the pump shaft were a little messed up, but not bad enough to keep the nut from going on. So now the pulley is on and the nut is tight...no wobble!
Now I need to chase down the correct belts....I'm getting closer!
Thanks again to all of you!
Old Aug 18, 2023 | 07:49 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
I need to remove/reinstall the power steering pulley on my '71 350/270 to do a pump rebuild.
When reinstalling, can I assume the pulley just goes all the way onto the shaft until it bottoms out?
Is there a torque spec for tightening the pulley nut?
With the pump on the bench, how to I tighten the nut if the pulley spins freely?
