68 wiper door last question
Old Jun 8, 2017 | 12:54 PM
carlisle61's Avatar
carlisle61
Default 68 wiper door last question
OK thanks for all the help with my questions. Almost all is working as it should. One remaining problem. The door does not seem to have enough vacuum to close. It opens well, and the wipers work as they should. When we turn them off they go to park correctly but the door will not close. Any ideas on how to fix?
Ernie
Old Jun 8, 2017 | 01:52 PM
Alan 71's Avatar
Alan 71
Hi Ernie,
Several things need to happen for the door to close.
The wiper switch must be turned to off so the wipers must move to the 'park' position.
This causes the plunger on the safety valve below the wiper arm to be 'depressed'.
This completes the vacuum signal to the wiper relay which then sends the vacuum signal to the 'close' side of the wiper door actuator….
which closes the door.
You need to test the relay to see if it's getting the signal to close the door and then sends the vacuum to the 'close' side (red) of the actuator.
Is that signal making it to the actuator?
Regards,
Alan
Old Jun 8, 2017 | 04:12 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Wow... from one Ernie to another..
68 Didn't use the plunger valve below the wiper arm, it was added to the 1969 production and stayed until the end.
The 1968 motor worked a bit differently than the 1969-1972 system.
My guess is there is an issue with the limit switch plunger on the firewall. When the plunger is pushed all the way in it will cut voltage to the motor. If the plunger is not pushing the switch all the way this would leave 12 volts on the brown wire that only has power when the motor is active and thus keeping the vacuum blocked to the wiper door tach solenoid.... and leaving the door open.
Willcox (Ernie)
Old Jun 8, 2017 | 07:24 PM
kansas123's Avatar
kansas123
Would an actuator with a very small leak cause it to not pull the door down enough?
Old Jun 8, 2017 | 09:45 PM
LT-1 kid's Avatar
LT-1 kid
there is no safety valve below the wiper arm on a 68, thats why 68 wiper
motors have 3 wires.
Old Jun 9, 2017 | 05:44 AM
carlisle61's Avatar
carlisle61
Thanks to all. This has been very frustrating, but with all the help thru this forum and another friend everything is now working as I should. Thanks again.
Ernie
Old Jun 9, 2017 | 06:53 AM
Alan 71's Avatar
Alan 71
Hi Ernie (W!!!),
Thanks for the info about the safety valve.
I think I knew that about 68 cars but had forgotten it. I need to write it on my hand to remind me!
Was there another way to prevent the wiper door from closing on the wiper arms before they had reached the 'park' position?
Regards,
Alan
Old Jun 9, 2017 | 10:00 AM
carlisle61's Avatar
carlisle61
Default 68 wiper door overide light
One more question on this subject. There is a light that goes on with the wiper door . Where does that plug in?
Ernie
Old Jun 9, 2017 | 10:17 AM
Alan 71's Avatar
Alan 71
Hi c61,
If you look at the electrical schematic Willcox posted you'll see a note 'A' in the upper right corner.
It indicates the wire from the warning lamp in the dash runs to the wiper override switch bracket below the steering column.
It's 'hinted at' but not very clearly shown in the 68 AIM.
Regards,
Alan
Old Jun 9, 2017 | 11:39 AM
0Willcox Corvette
Former Vendor
Originally Posted by Alan 71
Hi Ernie (W!!!),
Regards,
Alan
Just the over-ride switch inside under the column. But if the limit switch stays in the open position the motor keeps running and when this goofy motor is running there is power to the tach solenoid... When the motor is in the over-ride position it backfeeds voltage to the override switch bracket... crazy
To 68 wiper door last question
