1976 Corvette clock
Old Jun 12, 2017 | 09:31 AM
jobber26's Avatar
jobber26
Default 1976 Corvette clock
Just out of curiosity, has anyone had to put 4 clocks in their C3 Corvette? I am in the process of investigating why my 3rd clock, with the improved chipboard, quartz technology, (ZIP Corvette) part has stopped working again after driving around for about 1/2 hour... I do have the car sit for extended periods in which the power is turned off to save a battery charge loss. Could this affect how this technology performs? Maybe it needs a constant electrical supply. It seems odd that I have to install/replace a clock in my car every 3-4 years, unless this is some of the lousiest technology known. It is also undesirable to keep removing the dash, gauge cluster, console, etc, esp. since mine is installed perfectly and the constant removal will eventually yield a scratch or scar and make the interior look like ****. Maybe I should just replace the clock with a little lighted sign that says, "Time is irrelevant when you're driving this car".
Old Jun 12, 2017 | 11:52 AM
MelWff's Avatar
MelWff
I replaced mine years ago and have had no issues. Turning the power off shouldnt do anything to the clock but you are better off with a tender. Have you checked if your alternator is putting out between 13.5 to 14.5 volts and no higher?
Old Jun 12, 2017 | 05:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Something must be zapping the clock, I've had not issues withe the new clocks or the conversion kits to fix the clocks. I put a conversion kit in my 72 about 10 years ago and it's still working.
If you are doing a quartz conversion yourself, I always bend the grounding tab inside the clock and I also make sure the back wall where the grounding tab hits is free of paint.
Willcox
Old Jun 13, 2017 | 07:35 AM
jobber26's Avatar
jobber26
Default Alternator
There is a possibility the alternator, esp. the internal regulator may play a role in this. I have an aftermarket 100amp alternator on the car to support a stereo with internal booster, halogen headlamps, hi performance (MSD) distributor & 9mm wires, etc. and it may have affected the clock, but the first 2 clocks were retired before this alt was installed... at last check, the meter was saying that this new alt was charging at 112amps, too.
Old Jun 13, 2017 | 01:58 PM
NRAROX's Avatar
NRAROX
Wilcox advice is good, as usual. Also consider fusing the clock, leaving plenty of wire so you can easily check. Start with 1 amp.
Old Jun 13, 2017 | 02:38 PM
MelWff's Avatar
MelWff
Default 112 Amps
I'm not a professional but my understanding is the only time your alternator should be putting out 112 amps is when it is fully loaded. Have you taken a voltage reading with a hand held gauge?
Old Jun 13, 2017 | 04:06 PM
7T1vette's Avatar
7T1vette
Unless your clock is getting an excessively high spike in voltage (unknown reason), it should not be harmed by any level of alternator output. The clock only accepts the amount of current it requires to run.
I suspect you have a grounding problem in the car (circuit board, ground wire connection, etc).
To 1976 Corvette clock
