Another LS transplant question - Carb look and EFI
Received 1,139 Likes
Yeah, it's a bit of a paradox. It's really more a tribute to the L88s outward appearance and great power. I had originally planned on using a big block, but then I thought about how heavy BBCs are and how huge they are in that engine bay and the potential for overheating, etc.,
The LS just seemed to make more sense. I do still want to have at least some semblance of old school appearance (carb) and get rid of that butt-ugly LS intake system.
http://www.superchevy.com/how-to/vem...1-crate-motor/
ignatz, I was planning for the LS327 and carb. When I told my wife that she said I was nuts and wouldn't be happy if it didn't have the same or higher H.P. then what's in my C6. Who would have thunk it ... I wound up getting such a good deal on a Connect & Cruise package LS376/485 & 4L70 I couldn't pass up the SFI.
Looking back, I did my swap in 2011 when some of those motors were still available. I really thought it over but in the end couldn't swing it in my mind. I bought a $7000 motor and a lot of this and that to make it work. It would not have come up to $20K but if time is money it would have been pretty close.
I haven't been able to find much on this particular question, so here goes. I'd like to plan an LS transplant in a '69 (to go along with a 5 or 6 speed transplant as well). I like the LS376 with over 500 hp. So.... I like the idea of fuel injection, but the LS engines are just not attractive in stock fuel injected form - and the air intake situation is ugly. So I want to go with the carbureter look. Plus, I want to install an L88 hood and it would look better to have a carbureter look under there.
What about buying the LS376 crate engine carbureted version and then installing a Pro Flo throttle body fuel injection system or some other EFI that mounts like a carb? I noticed the carb versions of the LS crate motors come with an ignition controller module. Can that work in conjunction with the aftermarket EFI harness?
Still in the planning phases here, so any input is welcome.
Now, about the carb.... What you gonna do about the IAT's? Ignore them?
Hey cv, I disagree, it looks purposeful! de gustibus non est disputandum
Here's the painted look
Would I do it again? I wanted a stock looking sleeper and didn't get that. I had to do a lot of extension fiberglassing to get the hood to fit. In the end I'm happy with it and the number of unknowns I would have had to overcome vs. carb was a bit much.
One more thing - the LS adapters push the motor up a bit and that led to driveshaft angle differences that had to be overcome. That is regardless of what induction system you choose. I think someone with some metal fab skills could maybe put the motor down some or hard mount it with a home-brew adapter and get a more conventional hood.
@ignatz - I remember GM offering those motors - $20k is quite a bit more than I want to spend for just the motor.
The Connect and Cruise packages that @77Blue mentioned look very attractive, though I would do a 5 speed.
@Patro46 - no personal offense as pertains to appearance. I just think the intake snorkel going off to the side just looks awkward. I guess I'm just old school that way.
Going with the single plane EFI manifold with, say, a Holley EFI throttle body that @SteveG75 mentioned sounds like a good plan. That would allow a carb style air cleaner assembly. I'm going to do some research to make sure it can fit under an L88 hood.
Yes, o as 2 others (Shark Racer and SteveG75) have already suggested. Start with the GM sequential EFI system and change the intake to use a throttle body so you can mount a carb type breather. You can also relocate the coils so you can install "pretty" valve covers.
Just don't go way backwards by using with an entry level TBI injection system.
I have a similar if not the Same hood. Gives plenty of room imop
Look at the Edelbrock Victor Jr as an example.
It will get you a very clean look.
