Tach problems
Old Sep 30, 2002 | 05:42 PM
bobt007's Avatar
bobt007
1st Gear
Default Tach problems
The Tach is running 1000 to 1500 rpms below actual rpms on a 1981.
Any ideas why?
Old Sep 30, 2002 | 08:48 PM
Geoff1340's Avatar
Geoff1340
Default Re: Tach problems (bobt007)
I'll trade you...mine reads 1000 or so RPM high. Don't know the fix either... :confused:
Old Sep 30, 2002 | 11:34 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Trade BOTH of ya! My '76 just stares at me when the tach should move.
Old Oct 1, 2002 | 12:29 AM
HawkIVette's Avatar
HawkIVette
Don't know if this will help you or not, but here goes.
When I had to replace my circuit board on my 75 ( keep in mind, 75 is when the vette went to electronic tach, though I don't know if was still electronic on the 81), there were instructions on "zero"ing in the tach needle after replacement of the board.
I think it went something like this.
With the key in the off position, your tach may read between 0 and 100 RPM. Turn the key to the on postion with out starting the car and the needle should go to "0". If it doesn't, you have to carefully pull the needle off the dial and replace it to point at zero. As I said, the key must be in the on position with the car not running.
Did this just start reading off, or has it always read on the low side? Your car may just have a curcuit board going bad.
To Tach problems
