Crossfire injection cams? And upgrades
Hi everyone i have a 82 vet collector edition cfi i just found out my camshafted has 2 flat lobes so will be looking to upgrde it soon also thinking of upgrading to a renegade intake and maybe better heads with maybe 194 vavle my question is what cam works best with this cars found a couple cam just wanted to hear any recommendations and maybe what your running and how you like it and of anyone has a video of there running that would be awesome these are the 3 i can remmber
Comp cams Xtreme Fuel Injection; XFI™ 252XFI
CRANE 114122
Crower 00904
CRANE 114122
Crower 00904
"Sounding angry" is just as much a function of the exhaust system as the cam. None of these cams will have the duration and centerline lobes to "sound angry" and still work with the 82 ECM
IF i were you, here's my $.02
Run the XFI252 with the Summit brand Iron Eagle heads under a Renegade intake with a Hypertech chip.
Some will argue the chip, but its running my 82 with a ZZ4 crate motor (10.0Cr, rollar cam) under a ported Xfire intake with stock injectors. All the math and conventional wisdom says it shouldn't work, but it does.
Yeah leading towards the comps but the crane 114122 are good also they had a good reveiw on grumpysvette anyone with a aftermart cam in there cfi got any videosalso i have a hypertech tech stage one chip
Sorry, no video and can't make one for you (just recently sold the car). But it did sound great. Think the high compression and high flow catalitic converter did that more than the cam. Just a note, I don't think you'll ever get the lumpy mean sound without overwhelming the computer. If you put the wrong cam in there all you will get is check engine lights.
Make a phone call- People like Chris Straub will most likely know how much cam you can use and not make the computer go stupid. OR hunt a custom chip to go with whatever cam you decide on. OR both.
