Rear strut rod question
Old Jun 19, 2017 | 05:50 PM
The Punisher's Avatar
The Punisher
Default Rear strut rod question
Are the rear strut rod bushings pressed in?
Old Jun 19, 2017 | 05:54 PM
Alan 71's Avatar
Alan 71
Hi P,
Yes, the strut rod bushings are pressed into place.
Regards,
Alan
You can just see the metal sleeve that's part of the bushing.
Old Jun 21, 2017 | 11:23 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The original strut rod bushings were actually made into the strut rod and not pressed in. The replacement strut bushings from GM and now in reproduction, had/have a metal sleeve around them so that they could be pressed in place. (show below)
Just a word to the wise, it's usually cheaper to purchase new strut rods vs. buying the bushings and installing them. (Or paying someone to install them).
https://willcoxcorvette.com/corvette...-63-74-correct
Willcox
Old Jun 21, 2017 | 11:35 AM
phil48315's Avatar
phil48315
2017 C3 of Year Finalist
Here is a link to Ecklers.
http://www.ecklerscorvette.com/1970+...d-chassis.html
lot of options available.
I would stay away from the racing rod end ones, and the heim joint ones.(unless someone here on the forum has used them and can give good feedback?)
We have had some race cars at the shop, With 4-link rear suspension With those ends and they were pretty loud.....clanky sounding !
I did all black urethane in my restored 1970 And was pleased with the ride.
Old Jun 21, 2017 | 06:31 PM
ddawson's Avatar
ddawson
Heim joint, over 3 years now. Not a sound or harness.
Mine are greaseable and I add a little once a year along with the rest of the ball joints.
Old Jun 21, 2017 | 09:38 PM
The Punisher
I was thinking about the adjustable ones with the poly bushings. As long as the poly bushings don't squeak.
Old Jun 22, 2017 | 11:08 AM
OldCarBum's Avatar
OldCarBum
That is what Van Steele recommended.
Old Jun 22, 2017 | 11:52 AM
OldCarBum's Avatar
OldCarBum
I just ordered new smart struts from Van Steele. They told me that the heim joint struts are great for track or autocross cars, however do require "proper maintenance" frequently. I'm not sure what that maintenance is however they recommended against them for a street driven car.
Old Jun 22, 2017 | 12:32 PM
Zorro O's Avatar
Zorro O
So far my adjustable strut rods have needed adjusting twice in just over a year. (Less than a thousand miles) That's also mean two alignments! I don't know why they did not double nut or put a bearing between the nut and strut so when the rod flexes it wouldn't undue the nut. If I could afford to do it over I would go with the heim joint because people on this forum say they stop the flex. Just yesterday I had the alignment shop drown the thing in red lock tight, we'll see how that goes. The adjustable rods gave me the best rear wheel alignment I've ever had as far as making both sides even, so I think it's worth finding a solution.
Old Jun 22, 2017 | 09:17 PM
The Punisher
That's good that they are so adjustable because I use the 10" lowering bolts on my car too slam it to the ground
To Rear strut rod question
