Dreaded engine squeak
Old Jun 22, 2017 | 03:41 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Moser28
The bolt that was removed was the short one. I couldn't find a long one when I was installing it and used the grease to hold it instead.
OK, I guess that's not the problem..............but that push rod doesn't look right. Maybe there's some casting flash in that passage??
Old Jun 22, 2017 | 04:06 PM
Moser28's Avatar
Moser28
It may have been caused by my hasty installation. I think that the rod wasn't sitting correctly on the pump lever which put pressure on the rod. On the engine side the rod was worn on the bottom. On the pump side it was on the top.
