69 Parking Brake Adjustment
)and the parking break pulls the cable but doesn't get tight enough to hold the car. In my service manuals it says to rotate the rear discs until the hole lines up with the adjustment screw. The problem I'm having is that when I rotate the rotor, whatever it is behind the hole moves with the rotor. I'm a car novice, but fairly handy and a quick learner. Hoping this will be a simple job to get started.
Thanks everyone.
I'm wondering if my brakes are stuck in the "on" position. Guess I need to remove the rotors, but not sure how difficult that will be if the PB is malfunctioning.
You need to position the adjustment hole so it's at the 6 o'clock position on the hub.
Insert your screwdriver and feel for the notches in the 'star' adjuster.
When the screwdriver is engaged move your hand and end of the screwdriver up, (away from the floor,) this rotates the 'star' and adjusts the shoes.
Tighten until the rotor will not move and then 'back-off' 6-8 notches.
Hope that the shoes aren't 'frozen' in place.
Regards,
Alan
Rotate until hole is at the bottom.
Rotor removed so you can see the shoes and adjuster.
Shoes at top.
Adjustment at bottom… rotate 'star' so it turns counter-clockwise.
Regards,
Alan
I read in the other thread that I should put the rotor on back the same way I took it off. In this case would it cause any problems to put it back on in such a way that the holes align?
In your case, I'd rotate the rotors in respect to the hubs, so you can access the adjustment hole, then use a dial indicator to check the run-out. Hopefully, you'll be within spec, which I believe is about 0.002-0.005"....or less.
I agree with lf4 that the rotor needs to be pulled off and clocked properly on the hub so the holes line up.
Regards,
Alan
This is the surface being seen in your photo. (concentric machining rings).
The paint stripe on the rotor and hub indicate where the rotor needs to be placed on the hub to minimize run-out.
