Rear brake binding on... and on...
Old Jun 23, 2017 | 03:39 AM
English Howie's Avatar
English Howie
Default Rear brake binding on... and on...
Left rear brake was binding, so we replaced the calliper and it's still doing it.
Any ideas please? My best guess is a collapsed flex hose, although it all looks good on the outside.
I'd be grateful if one of you bright guys can diagnose the problem...
Old Jun 23, 2017 | 05:16 AM
Antz81's Avatar
Antz81
Looking good and being good are two very different things.
Old Jun 23, 2017 | 06:25 AM
mrvette's Avatar
mrvette
Yup, first thing I would do is change both rear brake hoses, and also flush the lines really good....Blast some air and brake cleaner down the line going to the rear.....loose on both ends and so plenty of flow....
Old Jun 23, 2017 | 07:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Left rear brake was binding, so we replaced the calliper and it's still doing it...Any ideas...
Obviously, the problem wasn't the caliper.
...I'd be grateful if...you...can diagnose the problem...
Sticking ebrake shoe(s).
Old Jun 23, 2017 | 05:06 PM
7T1vette's Avatar
7T1vette
If the rubber lines connecting steel lines to calipers are old, they NEED to be replaced. They go bad internally and get gunked up inside. You can apply the brakes; but they will hold some residual pressure when you release the pedal. That drag will quickly heat up the brake...then the wheel... then the tire bead melts... then your rear end is throwing craps on the road.
Or, if you are really unlucky, the brake catches fire and burns up the entire car.
If you don't think so, just leave it like it is for a couple weeks.....
To Rear brake binding on... and on...
