Headlight "idiot light" on?
Old Jun 24, 2017 | 08:58 PM
Highlander1732's Avatar
Highlander1732
Default Headlight "idiot light" on?
I just got my headlights functioning mechanically after replacing a number of vacuum lines, both relays, a "T" fitting and rebuilding actuators. They work fine with the switch but the red "Headlamp" light in my center console also turns on with the lights. Is this supposed to happen, or is the light only meant to come on when the lights are left on wihen the ignition turns off? The alarm buzzer functions properly if the lights are left on with ignition off. 1975 if it makes any difference...Thank for your input.
Old Jun 24, 2017 | 09:25 PM
TimAT's Avatar
TimAT
There is a switch on the headlight mechanism that shuts off when the headlights are fully open. Kind of like an "IN-Transit" alert. The switches are plastic and easy to break. Sorry I don't have a good picture, but the switches are about 3/4 x 1 and have a 2 wire connector. They are attached to the links on the buckets- not hard to find.
Old Jun 24, 2017 | 11:24 PM
GUSTO14's Avatar
GUSTO14
1968-1982 Headlight Door Open Warning Switch.
photo courtesy Keen Parts Inc
http://keenparts.com/pages/detail.ph...70024&year=ALL
Good luck... GUSTO
Old Jun 25, 2017 | 07:20 AM
Brcmpbl's Avatar
Brcmpbl
Note that when you install the new switch, just snug down the nut that holds it in place - they are very easy to break as mentioned above. I suggest replacing the switches for both headlights at the same. I replaced the passenger side one on a 76 I had at one time, and a week afterward the driver side went. Plastic can get brittle with age.
Old Jun 25, 2017 | 07:46 AM
Highlander1732
Thanks all! I recognize the switch now as I remember installing it in the incorrect orientation early on. If I recall, when the light bucket flips up, a portion of the bracket is supposed to depress the switch and turn the light off? I will look at my AIM to see if the exploded view shows the correct orientation. I do remember putting the passenger side together and referencing the driver side for the corrrect orientation.
Old Jun 25, 2017 | 07:47 AM
Highlander1732
Old Jun 25, 2017 | 07:50 AM
Highlander1732
Until I am able to investigate and either reorient the switch to it's proper position or replace as needed, can I disconnect the harness from the switch? Or will that keep the console light on?
Old Jun 25, 2017 | 08:05 AM
Brcmpbl's Avatar
Brcmpbl
There's a little button the switch that depresses on part of the headlight assembly once the assembly is in the fully open position.
I don't remember if unplugging the harness from the switch works, I'd just try it.
Old Jun 25, 2017 | 08:17 AM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
As I recall unplugging the switch will make the light go off.
Old Jun 25, 2017 | 10:35 AM
TimAT's Avatar
TimAT
Unplugging will make the light go out= switch is normally closed. when the button is depressed, it opens and light goes out.
To Headlight "idiot light" on?
