Fuel delivery woes
Old Jun 26, 2017 | 10:19 AM
Darinm's Avatar
Darinm
Default Fuel delivery woes
Hi all, question on an issue i'm pursuing right now with my fuel delivery.
1980 with new 383. I've been trying to get my fuel pressure up to 6psi which is what the carb builder recommended.
I'm using a mechanical fuel pump and a holley regulator with bypass. I'm using the factory hard fuel lines for the inlet to the regulator and the return line for the bypass on the regulator. From the regulator, i'm using all -6 AN fuel lines and fittings which next go to an inline fuel filter, then to the fuel log and to the dual fuel inlets on the carb.
I've replaced the fuel pump which is rated for 6.5 to 8 PSI. I've put in place a new regulator and with the engine running the max fuel pressure i can get is 5psi.
First, i'm starting to suspect my fuel tank may be dirty since across 2 carbs i've had my float stick due to trash in the bowl. Each time, i've pulled the fuel filter and didnt find anything so that parts still a mystery.
Second, could it be the diameter of my fuel lines ? Could it be the hard line and -6 AN lines are not able to deliver enough fuel to get 6psi of pressure ?
If i end up pulling the tank and replacing it, i may just switch to an electric pump and run new fuel lines.
Any ideas where to look next ?
Old Jun 26, 2017 | 10:40 AM
Big2Bird's Avatar
Big2Bird
No where. 5 lbs is fine. Does it run Okay without starving for fuel?
Old Jun 26, 2017 | 10:56 AM
REELAV8R's Avatar
REELAV8R
5 psi should be plenty. If it should starve for fuel I would check the size of the line from the pump to the regulator. Is it 3/8" or better?
Old Jun 26, 2017 | 11:15 AM
Big2Bird's Avatar
Big2Bird
Has the in tank filter sock ever been changed?
Old Jun 26, 2017 | 11:34 AM
Darinm's Avatar
Darinm
So far as i can tell yes. Carb has clear fuel bowls and it seems to be consistently full.
Old Jun 26, 2017 | 11:48 AM
Darinm's Avatar
Darinm
Not as long as I've owned it. I wish there was a way to get a camera inside the filler neck to have a look around. Not sure if mine has a bladder or just a plastic liner in the tank to view the condition.
Old Jun 26, 2017 | 12:28 PM
Darinm's Avatar
Darinm
Correct. From the hard line it's 3/8" ID ending in a -6AN fitting.
Old Jun 26, 2017 | 01:04 PM
Big2Bird's Avatar
Big2Bird
Yes. You can look with a borescope type camera.
I actually changed the sender and sock via the fuel door. Rubber lines too. Just have to be patient.
The sock was collapsed.
Old Jun 26, 2017 | 09:05 PM
george2066's Avatar
george2066
Default an fittings size
cheat sheet for AN
6AN is 6/16 or 3/8
5AN is 5/16
4AN is 4/16 or 1/4
just put 16 behind the AN number
3/8 from tank to fuel pump then to carb, 5/16 return
Old Jun 27, 2017 | 09:45 AM
MN80Vette's Avatar
MN80Vette
I have an '80 also and worked inside the tank when I switched to EFI. Your tank is lined, no bladder.
I had my tank out of the car because I modified the lines in and out, but I am pretty sure you can replace the sock filter from the top without removing the tank from the car.
Old Jun 27, 2017 | 10:07 AM
Darinm's Avatar
Darinm
Thanks for the info. Tank removal doesn't seem too difficult. So it might be worth the effort to remove it, replace the sock and inspect/replace the lines while i'm at it.
Old Jun 27, 2017 | 02:02 PM
Street Rat's Avatar
Street Rat
You can remove the sending unit while the tank is in the car. You can get to it from under the fuel filler cover.
Old Jun 27, 2017 | 02:13 PM
MelWff's Avatar
MelWff
have you tried reversing part of your set up, the fuel filter comes before the regulator.
To Fuel delivery woes
