How to hook up a Mini-Starter
Jun 27, 2017 | 03:16 AM
Hey!
Stock I have 3 cables. Battery, igniton and Relay. The new Mini-Starter only need Battery and Igniton.
Now the question: where to hook up the "relay-cable"?
Thanks, Günther
Jun 27, 2017 | 07:10 AM
Quote:
Originally Posted by
Günther-C3
Hey!
Thanks, Günther
Do you still have points? If so, you need a diode to hook it up. If you don't, tape it off.
Jun 27, 2017 | 07:14 AM
I´m sorry, what is "points"?
Jun 27, 2017 | 07:32 AM
Günther-C3
Does your distributor have points still?
The relay wire is to bypass the resistor wire during start up.
Jun 27, 2017 | 07:43 AM
Jun 27, 2017 | 07:46 AM
Günther-C3
You don't need the "R" wire. Tape it off and start the car.
Jun 27, 2017 | 08:00 AM
Thank you!
Jun 27, 2017 | 10:17 AM
Wow, sometimes I feel old....
Jun 27, 2017 | 12:32 PM
73racevette
LOL, me too.
Jun 27, 2017 | 01:51 PM
Why are you feeling old?
Again, are you sure I don´t neet the relay-cable? I only have the "hall-effect" from Pertronix, not the whole igniton system.
This is what I have:
http://www.corvetteforum.de/thread.p...lightuser=7367
Can somebody explain me how to do with the diode?
Thanks, Günther
Jun 27, 2017 | 02:15 PM
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Günther-C3
Thanks, Günther
Do you still use the ballast resistor wire in your coil C+ voltage supply line?
Jun 27, 2017 | 02:54 PM
Because points were really common back in the 60/70's
If your using a pertronix you should have added a 12V wire to it. In that case you don't need the R wire to start the car.
If you look at step 4 on both pages here they explain the diode.
http://www.powermastermotorsports.co..._GMMiniSta.pdf
Jun 27, 2017 | 03:36 PM
69427
Yes I do.
Jun 27, 2017 | 03:39 PM
ddawson
The 12V of the pertronix wire is connected to the igniton coil + terminal. Is that wrong hooked up?
Jun 27, 2017 | 04:17 PM
ddawson
And 80's... I am not that old.
But, yes if you had a car in the 70's, 80's or earlier, it almost definitely had points. I am thinking there may not have been a car made in the 60's or before that did not have points, but I can't confirm that at the moment.
Jun 27, 2017 | 04:23 PM
Adding this, if this is what you had and your new starter doesn't have an R just add the diode.
Jun 27, 2017 | 04:29 PM
ddawson
Yes, the picture is right. Can you tell me the thing with the diode? What is the exact name of the diode, so I can buy it?
As I know, the diode is then connected from the big plus terminal of the new mini-starter to the wire, where it was connected at the "R" terminal at stock application. Is that correct?
Jun 27, 2017 | 04:32 PM
Jun 27, 2017 | 04:37 PM
Günther-C3
Yes I do.
Gunther. Forget the "R" wire. You need to operate the Pertronix from a full 12volt keyed on source. Tape off the ballast wire, and the "R" wire, and use a #14 wire from the "IGN" fuse to the coil + terminal.
This is the way it's supposed to be wired up.
http://www.pertronix.com/docs/instru...eets/91141.pdf
Jun 27, 2017 | 04:46 PM
ddawson
Great link! Now I know how to do!
